SRS light is ON
SRS light is ON
I have a 97 integra LS 4door. SRS light has been on for the last couple of weeks. Have searched online and tried that SRS reset with a paper clip. It blinks twice at the end of the procedure, which according to the article, means its reset correctly. However, after i try starting the car, SRS light returns.
Does this mean my srs is toast? Need a new srs switch...
Re: SRS light is ON (steam)
Have you try Team-Integra.net, they have an artical about reseting your srs light. i know this because i replace my steering wheel to the spoon steering wheel and a quick diconnect hub, but after a while i feel unsafe due to it being my daily driver so i follow the SRS reset article to reinstall my gsr steering wheel and it works but it's really tricky. If it's your first attemp, it will be easier if you have another person counting the srs light flashes and you just focus on the steps and you have to be quick. It took me on my third try to get it. If this doesn't work then maybe your srs harness plugs are loose or the metal pins inside the srs connectors arent touching. good luck.
