Squealing when braking.
I have a 98 civic ex. When I brake I hear squealing noise from the rear end. Could this be the brake shoes? or the pads. When I went to kragen the counter salesman said its rare that you change the rear pads for this car and it should be the brake shoes. Is he right?
Re: (vltnolia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vltnolia »</TD></TR><TR><TD CLASS="quote">Is it easy to change the brake shoes on your own. I usually try do my own repairs if I know I am capable of doing it. </TD></TR></TABLE>
yes the rear are easier to change then the front
Can you give me any info on how to change it? its a 98 civic ex. Do I have to buy a hardware kit if I do decide to repair the shoes or can I use the old ones?
I just swapped my old ones for new ones. Wasn't to hard to do but it took me 2 hours to do the left side and an hour to do the other. I say pretty good job for doing this my first time. Okay, I swapped them out and there is no more squealing. But, the brakes feel a lot softer then before and I have to pull the ebrake a little bit more then before in order for the car to stop. Is this normal? I tighten the clevis A and B a little tighter then before. Could this be the cause?
Re: (vltnolia)
if its drum breaks you have to make sure when u put it all back together it has minimal play, so when u spin it there is a little resistance so that its a tight fit but not too tight. if done that then check all springs. thats just my advice
rovafa2002
01-28-2015 08:14 AM
pityocamptes
19
03-02-2012 02:26 AM
hatchinprogress
14
08-28-2004 10:03 AM
