Squeaky drums
Squeaky drums
hey,
i recently replaced the drums on my 97 civic and have since had a really loud squeak as i slowly come to a stop. it isn't persistant throughout the entire stop, but right at the end. is there something i can lube up to get rid of this? the drums were not turned before replacing the shoes. could I have adjusted the shoes out too tight? thanks for any help.
Re: Squeaky drums
Wait, so did you replace the drums or the brake shoes? Because if the drums were new why would you need to have them turned?
Can you turn the drum manually when you replaced the shoes?
Re: Squeaky drums
i would take the drums off and have a shop turn them for you.
next time you put them on lighlty sand down the new shoes since your dirty grubby hands will be all over the lining materials of the new shoes.
wheel bearings dont squeek.. please stop saying they do ^^^^ wheel bearings are full of grease. if you dont have grease in the wheel bearing then they will make noise. that noise will be a growling effect or a rumble, not a squeek. a squeek is a vibration from two hard surfaces. i cant picture a greased unit squeeking
Re: Squeaky drums
you should lube the contact points in the drum/shoe assembly except on the shoe surface of course
usually all the contact points will be shiny from rubbing so they are easy to spot.
i forgot to do that once and it made some hella squeal.
Charlie Moua
09-17-2002 01:41 PM
