speedo problem
Old Apr 26, 2003 | 04:23 PM
JiVe's Avatar
Default speedo problem??
I have a speedo problem
i was on the highway going 100km/h..then the speedo drops to 0 km/h
i was like wtf...but my tach is still working...
then it jumps back up to reg. speed
n now it doesn't work anymore........speed doesn't go up?
what can be wrong?
please advise..
Old Apr 26, 2003 | 11:35 PM
2camsaam's Avatar
Default Re: speedo problem?? (JiVe)
does it still read mileage?
Old Apr 26, 2003 | 11:45 PM
BlueIntegraBoy's Avatar
Something similar happened to my tach. I don't know exactly what had happened. But my speedo did act funny once. Like when it reached 60 mph, the needle got stuck. But then I took my cluster out and moved the needle up and down a few times, then it worked properly.
Old Apr 27, 2003 | 12:37 AM
SpoonFedHatch's Avatar
first thing, check your VSS (located on top of your tranny and has 3 wires going to it)....just pull it out, clean it up, plug it back in, ans see what happens
ThisLittleSleepeR's Avatar
Default Re: speedo problem?? (rompwats)
check to see if the sppedo pin is still in place, should be like two bolts that hold the speedo sensor in.
Old Apr 27, 2003 | 07:46 AM
Caveman74's Avatar
It's either the VSS or the cluster. I replaced the VSS and mine still works half the time. So I got a used cluster. Good Luck!
Old May 10, 2003 | 08:32 PM
97civicdx's Avatar
Default Re: (Caveman74)
Same thing was happening to my 97 coupe. I did what he said, replaced the speedo with a used one, and it flutters no more. Thanks for the info, guy..................
Old May 10, 2003 | 09:47 PM
Comfortable Rock's Avatar
same thing happened to me but my tach did it as well. Mine was my battery not holding charge.
Replaced battery and I was good to go.
Old May 10, 2003 | 09:53 PM
allmtr's Avatar
Default Re: speedo problem?? (Comfortable Rock)
i have a speedo problem too... it gives me a mean rash down there... hahahaha
Old May 10, 2003 | 10:24 PM
Trial User's Avatar
Default Re: speedo problem?? (allmtr)
I had this problem and people told me it was the vss and not the speedo. They were wrong. I got a new cluster and it went away.
Old May 10, 2003 | 10:30 PM
allmtr's Avatar
Default Re: speedo problem?? (Trial User)
i got a prescription cream and it went away
Old May 11, 2003 | 06:39 AM
97civicdx's Avatar
You better warn the last gal u got jiggy with, lolol
Old May 11, 2003 | 06:51 AM
krazyDOHC's Avatar
Default Re: speedo problem?? (97civicdx)
if it is the vss.....you will get a check engine light!!! it is most likely something else
Old May 11, 2003 | 07:11 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: speedo problem?? (krazySOHC)
If the VSS didn't work then he'd get a check engine light and wouldn't be able to hit vtec.
The problem you have sounds like the common problem for civics....its the speedo. 200 bux to replacement of just swap it out with a known good one.
Also mileage will not work when speedo doesn't.
Old May 11, 2003 | 11:48 AM
Trial User's Avatar
Default Re: speedo problem?? (Apex i ITR)
Ebay is where its at. I bought one with a tach because my DX didn't have one.
Old May 13, 2003 | 01:11 PM
97civicdx's Avatar
Thats where I got my EX cluster too. Now I have the tach.
Old May 13, 2003 | 02:13 PM
Trial User's Avatar
Is your off a little too? Mine reads too high. It also goes past 7000 and the fuel cut kicks in around 6500.
Old Jul 1, 2003 | 08:49 AM
~~~InNeEdFoRsPeEd~~~'s Avatar
* B A N N E D *
[QUOTE=Also mileage will not work when speedo doesn't.[/QUOTE]
my mileage is still showing that its working, but the tech jumps up and down and sometimes don't move at all......rpm tech works find also, what can it be?
Old Jul 1, 2003 | 09:00 AM
jolt-tsp's Avatar
Default Re: speedo problem?? (~~~InNeEdFoRsPeEd~~~)
I posted this same thing a while ago. I fixed it though. Your cluster isn't getting enough power or it has a loose connection. If you haven't messed with your wiring I go for the loose connection. If you have, make sure your switches/wiring/etc is rated for its application.
Old Jul 22, 2003 | 01:12 PM
B18B EK's Avatar
Default Re: speedo problem?? (jolt-tsp)
Can you use a d series vss in a b series tranny? Mine just **** the bed yesterday after getting my quaiffe installed. Maybe it just needs cleaning, I'll try that first. By the way the quaiffe is ridiculously awesome!
blinger
11
Mar 26, 2024 08:08 PM
406EVO
May 18, 2016 11:26 AM
mikej94civex
May 25, 2010 05:09 PM
burgandybeast
Nov 2, 2007 02:30 PM
esoterEK..
Sep 30, 2006 02:48 PM
