Speed sensor failure??
Old 09-21-2012, 02:27 AM
ReL3nTLesS_Ek9's Avatar
Default Speed sensor failure??
Ok here's my issue...I was on my way to work and I was getting on the on-ramp to the interstate in my 98 dx civic hatch 5spd and i was in 4th gear moving pretty swiftly (probably around 5500rpm but cant tell for sure because cluster is tach-less) and as soon as I engaged the clutch and shifted into 5th, the speedometer went from around 85 mph to 0 in a split second and the CEL came on. I was worried that i blew the motor but the car continued to run and drive perfectly normal. No smoke no shakes no nothing. I have not had the chance to get the CEL read because when I got home I took the grille, headlights and front bumper off to replace bumper support and rad support from previous accident (previous owner hit a dog and tweaked both a bit and broke headlight brackets) so it cant be driven until the rest of my parts come in. I thought maybe the cluster just crapped out on me and i had an extra cluster from my 99 hatch laying around so i swapped it out and still had the same problem. My thoughts are a bad speed sensor located on the tranny but i am not sure. Car still starts right up and drives fine just don't have a cluster with a tach and now the speedometer doesn't work at all (just stays pinned at 0mph) so its kind of annoying. Anyone have any ideas on what this could be?
Old 09-21-2012, 02:44 AM
CO671's Avatar
Default Re: Speed sensor failure??
You can pull the code without a scanner, try this method:
https://honda-tech.com/forums/showpo...63&postcount=8
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old 09-21-2012, 03:32 AM
Ok I tried that with the paper clip in slots 4 and 9 and at first when i turned the key to the on position the light would come on for about a second and blink once then remain steady. I tried it a few more times to be sure of what code i was getting and the same thing every time then i did it without the paper clip in and the same thing. Then i put the paper clip back in and tried and no light at all...now i cant get the damn CEL to come on at all yet my speedo still doesn't work...I think i somehow cleared the code...FML help me please :\
Old 09-21-2012, 03:53 AM
EF9_TryMe's Avatar
The light will blink quickly to indicate one.
A long flash will indicate a 10. What is so hard to understand ?
Old 09-21-2012, 04:02 AM
Did you even read what I said? It did the same amount of blinking for the same amount of time, with or without jumping the service connector and now it wont come on at all.
Old 09-21-2012, 04:35 AM
Technical Hero
HondaPartsHero's Avatar
http://www.justanswer.com/honda/14k3...ine-light.html
Old 09-21-2012, 05:27 AM
Thanks for all your help guys!! I am reluctant but not ashamed to admit I am a n00b and was doing the whole paperclip coding thing wrong but it was in fact a 17 (speed sensor) so I will be getting that within the next few days. Looking forward to learning lots more from you guys and once again thank you VERY much.
Old 09-21-2012, 09:37 AM
EF9_TryMe's Avatar
Old 09-21-2012, 09:40 AM
fragmare's Avatar
Before you run out and buy a new Speed Sensor, test the electrical connector with a multimeter. I just helped a guy on here who had bought a new VSS and it turned out his connector went bad. Your problem might be as simple as fixing an open wire or replacing a connector.
Old 09-21-2012, 12:07 PM
Originally Posted by EF9_TryMe
Whatever bro this forum is here for people with more knowledge about these cars to help people with less. If you don't like helping then why are u here? For attitude and cockiness? Thanks but no thanks...ur 2cents is not needed and was not helpful whatsoever.
Old 09-21-2012, 05:58 PM
EF9_TryMe's Avatar
Attitude ? Troflcopter.
Avoid jumping into a non-serious matter and turning it into an argumentative conclusion.
Please go more in depth, and describe how cocky my personality is based on what I
have stated. If the falling little yellow guy, and my question prior to the symbol posted
up above tickles your cherry then you have seriously got some issues underneath
your neck.
I was trying to be nice, but you responded in a very rude way leaving me with no
other option.
Old 09-21-2012, 07:12 PM
Technical Hero
Back to the tech please and keep your bickering to pm before this gets locked
Old 09-22-2012, 01:08 AM
fragmare's Avatar
Agree. This is Honda DIY, we all try to help each other out here. That's kind of what this community is known for.
Old 09-22-2012, 05:15 AM
EF9_TryMe's Avatar
^exactly.
Old 09-22-2012, 06:24 AM
Yoitshector's Avatar
Check you connector. I had replaced the VSS and was getting ready to replaced te cluster ended up being the connector was corroded up the butt. You can also test your VSS as well found this out after I replaced mine.
Old 09-22-2012, 09:06 AM
The easiest way to test my VSS is probably to switch it with the one from my other ek hatch right?
Old 09-22-2012, 04:03 PM
That would be easier than lifting your car
Old 09-22-2012, 05:30 PM
Ok...My other hatch is at my parents house in another state but i go there often so I will just switch them next time i go. Quick question...Is it normal for D16y7's to have s40 trans? I always thought s40's were Si trannys.
Diversion
08-23-2009 10:41 AM
d_EG COUPE
14
04-10-2009 01:15 PM
Civicthusiast
02-17-2009 08:30 PM
burgandybeast
11-02-2007 02:30 PM
CXtypeR
02-12-2007 05:57 PM
Quick Reply: Speed sensor failure??
