spark plug install issue, antisezze?
i put in some new plugs in my y7 and i didn't use that antisezze stuff around the threads, will i come into problems later on if i don't put some on their thanks
Re: spark plug install issue, antisezze? (sleepyhamsterlx)
Its not required but may help you out of a bind later down the road....maybe you should just get a lil on there...its only a few bucks.
1 Post
it's a good idea,but as long as you don't leave them in there for 10 years,they'll come back out no problem.i never use it on my plugs.i do use it on rear LCA shock mount bolts though!
chris
chris
Re: spark plug install issue, antisezze? (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">it's a good idea,but as long as you don't leave them in there for 10 years,they'll come back out no problem.i never use it on my plugs.i do use it on rear LCA shock mount bolts though!
chris</TD></TR></TABLE>
Werd ......
Copper anti-seiz is your friend.
Werd ......
i have never had a problem but it is an aluminum head, anti-seaze is only about 7 bucks. If you pull the threads out of the head next time you change your plugs you're going to be kicking yourself in the ***. its worth the ten minutes to torqe them and add the anti-seaze.
Re: spark plug install issue, antisezze? (dogfood)
just curious, what happens if you would strip those threads out? that couldn't just be retapped could it? even if you could, a spark plug would be too small; and i don't think heli coil makes kits that big. wow that would suck to have to replace a whole cylinder head because of something stupid like that.
anyone ever had this happen?
