spark plug gap with turbo????
Old Dec 12, 2003 | 04:42 PM
hondaeg8's Avatar
Default spark plug gap with turbo????
what should the spark plug gap be at when running a boosted motor? ignition has been upgraded to an msd sci, blaster 3 coil, msd wires, and msd modified cap.
i've heard the gap should be smaller, but then i hear the gap should be bigger so it will burn the fuel better?
any thoughts on this?
Old Dec 12, 2003 | 04:43 PM
Del_Slowest's Avatar
Default Re: spark plug gap with turbo???? (stockhatch)
.030 ....thirty thousandths. This is so that the air will not blow out the spark
Old Dec 12, 2003 | 04:51 PM
b16ahybrid's Avatar
Default Re: spark plug gap with turbo???? (Del_Slowest)
depends on how much boot your runing.
5psi you will be fine with it at about .036
20psi it will need to be more like .028 give or take...
I run mine at .034 stock ignition with msd 6-al
Old Dec 12, 2003 | 09:08 PM
hondaeg8's Avatar
8-10 lbs of boost on the motor.
Old Dec 12, 2003 | 10:08 PM
94dxt's Avatar
Start big and close gap till you stop hearing it miss, or visa versa
Modified by 94dxt at 12:31 AM 12/13/2003
Old Dec 12, 2003 | 10:29 PM
Default Re: spark plug gap with turbo???? (94dxt)
if you just do .030 then you'll prolly end up with .032 or .031 b/c it's really hard to gap the plug perfectly. well at least it is for me
hondaeg8
Dec 8, 2004 08:18 PM
B20-T
Jun 9, 2003 03:58 PM
Type R 702
Mar 7, 2002 12:01 PM
