someone please help!
Old 10-21-2006, 10:35 AM
schpiel's Avatar
Default someone please help!
Okay, so I was going to do the y7 to y8 manifold swap, but then I realized i would just wait until I got all of my parts for my turbo build. I had already taken off the tb and fuel rail and whatnot. When I put it back together, it started fine, and then as soon as I tapped the gas and then let it idle, the idle began jumping back and forth from 1k to 2k, not just randomly, rhythmically. I double checked every single line making sure I hooked it up right. I am positive I did, b/c I used the exact same car parked next to it as a reference point. Hoping that maybe somehow the IACV just got dirty or something when I took it off, I took it apart again and cleaned it squeaky clean, and still I get the jumping idle!!! Can somebody please help me???
Old 10-21-2006, 11:14 AM
schpiel's Avatar
bump, im trying to fix this today, so any ideas please!!!
Old 10-21-2006, 11:28 AM
DC_RaceR's Avatar
Default Re: (schpiel)
You got a leak...
Did you use the stock TB or the Y8 TB?
You might have a TB gasket leak.
Old 10-21-2006, 11:29 AM
DC_RaceR's Avatar
Default Re: (DC_RaceR)
Check your Air pressure senser and TPS sensor.. It might be switch...
Old 10-21-2006, 11:31 AM
schpiel's Avatar
I am using the stock y7 throttle body, and I know the sensors are plugged in right. The throttle body gasket sheds new light though. You think its possible that old gasket could be causing the leak? I hope so...
Thanks for your help
Old 10-21-2006, 11:49 AM
marble hatch's Avatar
Default Re: someone please help! (schpiel)
i just had this problem when i swapped my y7 for a skunk2 its a vaccum leak mine was a gasket that didnt fit properly so i took out my studs and got rid of all the old gasket smoothed it down and it worked perfectly..
Old 10-22-2006, 11:39 AM
schpiel's Avatar
Alright I tried the new gasket and it still is messed up!!! What else could it be?!?!?
Old 10-23-2006, 07:46 AM
schpiel's Avatar
Okay, I am posititive there are no vacuum leaks. It is still messed up. I have heard that there could be some air in the coolant lines going to the iacv. Is this possible? If so, how do you fix it?
Old 10-23-2006, 08:53 AM
DC_RaceR's Avatar
There is a valve on the housing where the top rad. connect to. ( Engine side )
Old 10-23-2006, 11:44 AM
schpiel's Avatar
I'm not seeing a valve. I could just be completely missing it. Any more description or somewhere I can view this at???
Old 10-23-2006, 11:59 AM
sauceja's Avatar
Get some carb cleaner and spray around small areas of your manifold. If your engine reacts differently when sprayed then you will find your vacuum leak culprit.
Try this and you will be amazed. One of your vacuum lines could have a small hole from being pryed off or loose.
Could be almost anything but def. think its vacuum related. Also look around your map sensor.
Old 10-23-2006, 12:03 PM
schpiel's Avatar
Default Re: (sauceja)
aight, ill give it a shot, brake parts cleaner will work just as good correct?
91 crx savage
28
07-27-2010 11:10 AM
triple5soul4165
02-20-2009 03:20 PM
MildWater
21
03-07-2007 12:27 AM
max23
10-18-2005 06:14 AM
hondasport2000
27
08-24-2005 06:01 PM
Quick Reply: someone please help!
