Solid cel / code 0
Old 02-17-2012, 04:15 AM
jtjtjt's Avatar
Default Solid cel / code 0
Ok I'm getting a solid cel when I turn my ignition on ,
I have checked all grounds , all ok
Have replaced main relay and soldered some harness wires as some were burnt
When I turn the ignition on I hear the fuel pump , but not sure on spark
Only thing I haven't done is check with another ecu , ( mines is p28 chipped btw) , which I will do soon
The thing is the problem is intermittent , it happened a
Month back , I fiddled with a few things and it was fine for a month (car would start and drive )
Sometimes randomly the cel will Go off and the car will start , and sometimes the cel will flicker rapidly and back to solid
Question is , since this is intermittent , how likely is it the ecu is bad ? I have heard other people with the same problem but they cannot start at all , this will start randomly at times
Old 02-17-2012, 04:26 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Solid cel / code 0
Just swap ECUs. Playing a guessing game at this point is counter-productive.
Old 02-17-2012, 04:53 AM
jtjtjt's Avatar
Yh I would but I'd have to buy one and wait a week :/
Old 02-17-2012, 05:39 AM
The Grumpiest
Poor you. I wonder what it would be like when your ECU finally manages to die altogether? That weeks wait will be an eternity.
Old 02-17-2012, 05:58 AM
jtjtjt's Avatar
nevermind
Old 02-17-2012, 06:07 AM
The Grumpiest
??? I don't understand your response. You need another ECU to test to see if yours is on the way out and you won't get one because you have to buy one and wait for it to show up? And somehow we're supposed to tell you if your ECU is going out? And I'm saying if your ECU is on the way out, dies, and you didn't have a replacement what will you be doing then?
Chances are it is your ECU.
Old 02-17-2012, 06:08 AM
Stoodybayker's Avatar
If you can't do any intelligent diagnostics, swap and guess.
Old 02-17-2012, 06:36 AM
jtjtjt's Avatar
I have ordered a new ecu , it's on it's way
In the meantime I just want to see if any one else has any experience with this
Because from what I've read if the ecu is the problem , then the car will not start in any condition .
So even though I know the chances are it's the ecu , ^^ this makes me think otherwise
Old 02-17-2012, 07:25 AM
The Grumpiest
There is no concrete set of symptoms for ECU failure. Sometimes they continue to work causing issues and sometimes not. And with a chipped ECU thrown into the mix then who knows?
Old 02-17-2012, 07:34 AM
jtjtjt's Avatar
Ok good answer , will have to wait for the ecu I guess :D
Old 02-17-2012, 07:40 AM
The Grumpiest
Have you tried to pull a code? And! Double check the ECU ground at the thermostat.
Old 02-17-2012, 10:14 AM
jtjtjt's Avatar
i havent tried pulling a code because i assumed since it was constantly lit that it would be the same when i try to pull a code, but ill try any way
i have done the thermostat ground a few times , it was one of the few things i play around with which SOMEtimes turns the light off
Old 02-17-2012, 10:16 AM
Former User's Avatar
Car? Engine? Set up?
Old 02-17-2012, 12:05 PM
jtjtjt's Avatar
98 civic , b18c1 turbo , neptune ecu on p28
Old 02-17-2012, 12:09 PM
Check whether hood fuse 44 or dash fuse 13 is loose.
Old 02-17-2012, 01:51 PM
jtjtjt's Avatar
do you know what they are for ? ill have a check tomorow
i have checked under hood ecu fuse which in the past was blown
have also checked under dash alternator fuse
EDIT: just searched them up and i believe i have tested them
Old 02-17-2012, 01:52 PM
The FAQs sticky has very nice fuse box diagrams. Click FAQs in my signature.
Old 02-17-2012, 02:10 PM
jtjtjt's Avatar
yeh sorry i did a search and found em, already tested them
Old 02-17-2012, 02:12 PM
Is either a little loose? Have you tried replacing them?
Old 02-17-2012, 02:15 PM
bsublime44's Avatar
we in the same boat, atleast ppl are responding to your post
Old 02-17-2012, 02:24 PM
jtjtjt's Avatar
ill replace them both tomorow , what would you recommend after this ?
Old 02-17-2012, 02:29 PM
It's multimeter time.
Old 02-17-2012, 02:46 PM
jtjtjt's Avatar
haha , what would i do ? havent got access to one so will have to borrow or get a mechanic to do it
94civiccpe
07-18-2013 07:48 PM
fog raw
15
11-08-2011 09:58 AM
stunn'd
07-11-2008 06:37 PM
liquidxEG
02-22-2005 03:46 PM
Quick Reply: Solid cel / code 0
