Solid CEL, anyone help!
Old Dec 5, 2010 | 12:43 PM
Track Beast's Avatar
Default Solid CEL, anyone help!
Okay, so heres the low down. When I got the Car the CEL engine light was on, checked the code with a jumper wire. Came out to #3 MANIFOLD ABSOLUTE PRESSURE. Ordered the part replaced it, reset the ecu the correct way and the CEL light went away. Checked it again the CEL light is SOLID. But it still didnt fix the problem. The car still wont rev past 5k rpm. anyone help me out really wanna get the car running.
Old Dec 5, 2010 | 12:54 PM
delsolo95's Avatar
Default Re: Solid CEL, anyone help!
0 (defined by CEL remaining on steady both without and with the service connector jumped) - indicates ECU power or ground problem when engine will not start; begin by checking the three main relay fuses and the G101 ground attached to the thermostat housing.
Read more at https://honda-tech.com/forums/showth...ktrack=kcplink
Old Dec 5, 2010 | 12:55 PM
how do i check the ground on the thermostat also what about the ecu power?
Old Dec 5, 2010 | 01:04 PM
delsolo95's Avatar
i was thinking the ecu is bad. try replacing it with a similar one from a friend. well make sure the ground on the thermostat is clean and tight. ecu power....better get a manual and a digital multimeter and start checking with key on and off.
radicaled434
Feb 23, 2013 06:45 PM
honda_aus87
Mar 26, 2011 08:01 PM
japek
Mar 19, 2010 08:34 PM
jpar195
Apr 7, 2008 12:01 PM
RexB16
Jun 3, 2005 10:34 AM
