sohc tranny making noise[ bone stock dd]
Old 04-25-2008, 04:59 PM
MK1 deR's Avatar
Default sohc tranny making noise[ bone stock dd]
anyone heard a sohc tranny make a loud rolling noise only when the clutch is NOT engaged..?? is a tob? https://honda-tech.com/zero...&id=1#
Old 04-25-2008, 05:11 PM
fastrc2's Avatar
Default Re: sohc tranny making noise[ bone stock dd] (MK1 deR)
when you say not engaged, do you mean the pedal is pressed? this could be the throw out or the pilot bushing. what kind of noise, a squeal is the pilot.
Old 05-08-2008, 04:50 PM
MK1 deR's Avatar
Default Re: sohc tranny making noise[ bone stock dd] (fastrc2)
i ment when the pedel is not pressed...is that th e throw out bearing?
Old 05-14-2008, 01:26 PM
809JDM's Avatar
no its not the release bearing. I had the same problem. I replaced the bearing, put everything back together and still had that annoying sound. Its something I believe in the gear box, I just ended up buying a new tranny. Problem fixed!!!
Old 05-14-2008, 02:25 PM
97civicdx's Avatar
Default Re: (809JDM)
Its the bearing on the other side. I cant remember what its called off the top of my head.
I did what the guy above did, get a used tranny coz mine whined pretty loud with the clutch pedal not pressed.
I still have the whining trans that grinds third gear as a spare once i can get it rebuilt
agent420
12-26-2007 07:49 PM
ericlee303
10-06-2005 07:55 AM
Emshhh
11
02-02-2005 11:10 PM
NickW
10
07-25-2004 01:25 AM
GSRacer1
05-31-2004 11:33 PM
Quick Reply: sohc tranny making noise[ bone stock dd]
