So what's the final word on the rear quarters?
Hello,
My 00 hatch is perfect on one side, but the other side there is rust starting to form :/. I'm going to take care of it in the summer. But the thing is, although I want to do things right, I don't really want to throw a grand at a body shop to fix it perfectly at a car that's worth two grand and is a daily driver which sees winter...being realistic, that's just not a great use of money..
Anyways, it's just starting to bubble at the rear quarter, so I'll just grind it away. I don't think it will be necessary to weld any new metal in. However, under the good old infamous rubber piece which goes around the wheel arch, there is rust... and since it's so thin I don't think I can just grind it away, it's probably rotted though. So... I'm not sure what to do. I might just do the prep, then get a body shop to do their thing in terms of getting that arch perfect (with new metal), and then I'll put body filler (just a tad)/primer/paint. Not really sure how the body shop is going to do that though, doesn't seem like an easy task...
But, what do I do with that rubber piece. Do you guys just throw it away since all it does is make it worse? Should I throw mine away now, even before I fix it since there's no point to them? Or do you leave them since they actually protect something?
Also, I was wondering, why did Honda make that arch bend, such that it's parallel with the ground? Is there a point to that? I don't really see the point of it being like that... why not just cut it away or roll it upwards the same way one would do if you're trying to run big wheels and you're rubbing?
Just want to know the best way to do this as I want to do it right the first time and not have to bother it again..
Thanks.
Thanks.
Seagull Management
Re: So what's the final word on the rear quarters?
Hello,
buy a 1/4 pannel extension and replace what you need to replace or the whole damn thing up to you,
if your not good with cut off tools or, grinder, or welding i would have a shop do it,
but you doing the prep will save you money as long as you do it good and the shop doesnt have to fix anything...
-[95cxhatch]-
14
02-14-2006 08:31 AM
NXLude
10-11-2005 05:21 PM
blackfrohatch
02-02-2003 05:11 PM
