Which Size Thread Should I Use?
2 Attachment(s)
I'm restoring the thread of the motor mount bolt and motor mount thread in the chassis of 95 civic.
Which exact size should I use to restore? The bolt from Honda is M12 x 115 i believe... M12 x 7.5 M12 x 1.5 or M12 x 1.25???? Attachment 524771 Attachment 524772 |
Re: Which Size Thread Should I Use?
The honda bolt is M12X1.25
So....use a M12x1.25 tap to clean it up. 12mm bolt. 1.25mm between thread points. That's what it means. |
I stripped that one on my teg, simple fix cut it off I used a plasma cutter due to limited apace the welded on a m12x1.25 nut. I'd just use a new nut idk where you'd find bolts THAT big/long as the OEM one not to mention the same grade.
Originally Posted by B serious
(Post 49776739)
