sir2 TB gasket
sir2 TB gasket
does anyone know which car tb gasket i should be using for a b16a sir2 throttle body
i tried a 99-00 si gasket but it didnt fit unless adv auto send me the wrong one
need a gasket that will fit this
Modified by komat at 2:54 AM 1/12/2006
Re: sir2 TB gasket (komat)
When I put my skunk2 im on, I was having a problem with a leak in that area. I used a y8 gasket and it fixed my problem. Not sure of your mods, so tough to say if the same is true for you.
-Shane
-Shane
try a del sol vtec, like a 1994, i think htose will work.. but the 99-00 SI (Sir form me, yay canada) should have worked..
Re: sir2 TB gasket (postman)
just tried one from a del sol didnt work
does anyone know where i could get a gasket for my TB for my 2nd gen b16a(sir2)
****, i always thaught a sol Vtec had almost all interchangeable parts with the SiR 2
Here's the piece for the SiR 1
Throttle Body Gasket 16176-PR3-010 90-91 integra
so im thinking maybe an obd1 LS Tb gasket would work?
worse to worse, im sure you can find gasket bulk material and make you're own...
Re: sir2 TB gasket (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">****, i always thaught a sol Vtec had almost all interchangeable parts with the SiR 2
worse to worse, im sure you can find gasket bulk material and make you're own...</TD></TR></TABLE>
the 90ls is the same as the pic i showed unless adv auto has it wrong
I think it looks like you need an automatic gasket. I would try an automatic 94-01 LS gasket. They seem to be longer than the other ones.
http://www.hondaautomotivepart...81%29
that's what the '95 del sol vtec TB gasket looks like. it's cheap, just go to a dealer to buy it.
civic_driver
09-25-2005 11:51 PM
