Si Trouble
Old 10-22-2007, 10:46 AM
spyder_Si's Avatar
Default Si Trouble
Ive got a 2000 Civic Si. the trouble im having is loss of power car on idle runs great under a load like crap. ive changed o2's the fuel filter spark plugs. checked timing its good. also when it hits vtec it doesnt go vtec works just flattens out. the CEL is PO172 i think. its fuel system to rich. any help would be great before i go spend a ton of money getting it looked at. thanks everyone.
Old 10-22-2007, 06:39 PM
spyder_Si's Avatar
Default Re: Si Trouble (spyder_Si)
anyone?
Old 10-22-2007, 06:41 PM
EJ1chevelle's Avatar
check all you IVAC and TPS type connections... i had a similar problem with my jdm b16 and it was a bad tps connection.
Old 10-22-2007, 06:42 PM
Hardedge's Avatar
Is it possible you have sticking injectors? Did you reset the ECU after changing the sensors? Commas and more info could help.
Old 10-22-2007, 06:48 PM
spyder_Si's Avatar
Default Re: Si Trouble (Hardedge)
yes i have reset the CEL's and still same problem.it all started after i put a new VSS in.
Old 10-22-2007, 07:01 PM
Lordofdark176's Avatar
put some lucas injector cleaner in ur gas tank and tell us if that fixes it.
Old 10-22-2007, 07:36 PM
spyder_Si's Avatar
Default Re: (Lordofdark176)
also forgot to say that my vtec feels like im hitting the rev limiter at 6k rpms
Unphzd
09-14-2010 08:51 PM
KidVicious
07-19-2009 07:24 PM
tahenry88
12
12-29-2008 03:05 PM
MIGPA26
06-06-2008 11:16 AM
SlammedDC2
10-04-2005 09:24 PM
Quick Reply: Si Trouble
