Shut down when boosted?
Old 07-06-2010, 01:11 PM
Tyme2Breathe's Avatar
Default Shut down when boosted?
I'm running a newly boosted D16Y8 @ 5 PSI with NGK Iridium IX Plugs. It's completely stock otherwise. My problem is that when the boost kicks in the RPMS bog down, causing erratic IDLE. If I apply any gas the car shuts off. Once I restart the engine the erratic RPMs disappear. Anyone heard of this? Can you point me in the right direction?
Old 07-06-2010, 01:21 PM
roadsqueegy95's Avatar
Default Re: Shut down when boosted?
Tuned?
Old 07-06-2010, 01:24 PM
No tune. Turbo was was installed about three weeks ago. It ran fine up until Mon.
Old 07-06-2010, 02:13 PM
Retired Moderator
EsotericImage's Avatar
Dude, you cant just slap a turbo on and expect it to run right.. I see you need alot of research and maybe soon a new engine.
Take out the iridium's, throw in NGK 4091's
Convert to OBD-1 and get a tune!
Old 07-06-2010, 03:01 PM
phaphon's Avatar
true you need a tune should fix the problem mines bog when boost kickd it too the cause was my car running to rich
Old 07-06-2010, 04:07 PM
Deff get it tuned asap
Old 07-06-2010, 05:29 PM
Gunmetal_B20_Hatch's Avatar
this is sig worthy... someone do it.
EDIT: fck it, I will.
Old 07-06-2010, 06:20 PM
OK...I ordered the NGK 4091 Plugs from SummitRacing.com, unfortunetly none of the local auto stores carry them around here. I will get it tuned ASAP! Thanks for your help guys.
Old 07-06-2010, 06:35 PM
I hear you on no local stores carrying the plugs. Theres only 1 place that carrys them around me. I usually buy them out ever oil change, just because they only ever have like 8 plugs in stock!
Old 07-06-2010, 06:45 PM
While we are on the subject of turbos....I was wondering if anyone has any recommendations for motor oils to use ( I.E. weight 5W 30 10W 40 ETC. Eneos, Torco, Royal Purple)
Old 07-06-2010, 07:01 PM
phaphon's Avatar
i use cheap oil right now just because im still tryna figure out where my oil has been going i made a homemade catch can hope thats the problem...but yeah post dyno results plz..kinda sad out of three b16 turbos mines is the slowest one aftertuned but two of my exhuast valves were a little tight
Old 07-06-2010, 07:05 PM
I hope to get the tune done on FRIDAY, I will post the results.
Old 07-07-2010, 05:38 AM
Retired Moderator
I use 10-40 on my car. I change it every 1000 miles. So as long as it has the "approved for gasoline engines" stamp, its all just about the same (conventional oil)
But make sure you change it every 1000 miles.
Old 07-07-2010, 07:06 AM
apexi_rsx's Avatar
you should be running BKR7E NGks... you can not run stock plugs u need colder plugs!!!!!!!!!!!!!!!
Old 07-07-2010, 11:37 AM
Retired Moderator
^^ already been covered dooder.
Old 07-08-2010, 05:35 PM
phaphon's Avatar
cool cant wait to see dyno results...i was suppose to get a retune soon but blew my rings =( hahha
bowtieboy911
Engine Management and Tuning
06-04-2011 04:32 AM
crx6662
02-19-2009 05:19 PM
focuz_btch
01-23-2009 08:29 PM
vangc6780
04-09-2006 04:35 PM
turb
09-01-2003 04:46 AM
Quick Reply: Shut down when boosted?
