Honda S2000 Honda S2000
Wierd problem
Old Oct 7, 2007 | 08:54 PM
Eddie99's Avatar
Default Wierd problem
Hello!
Since a couple of weeks ago, I started to feel that something "hit" the gear shifter, everytime I changed into third gear, this just happends if I am changing into third gear when going around 25-30 mph, it's really wierd don't know what the problem is, I can still change gears it's just that as soon the gear goes in to third gear, it feels like it gets hit by something, almost like when you release the clutch to early when changing gears.
I am also thinking about changing the clutch, I am not the guy to do it my self, does anyone know how much everything will be if I will take it to a dealer?
Old Oct 7, 2007 | 09:05 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Wierd problem (Eddie99)
might be bad driving habits... next time try doing it slowly, tell yourself clutch all the way in and in 3rd before taking your foot off the clutch....
if u still feel it.. change out the tranny fluid... worse case your synco might be going out...
but remember S2K's have notchy trannies to begin with
Old Oct 7, 2007 | 09:24 PM
Eddie99's Avatar
Default Re: Wierd problem (S@nt0s)
Ah okey. Well it feels the same as when you shift gears when the engine is cold and its cold wather outside, the gears are very notchy and sometimes hard to put in gear until the engine gets hot, but it always feel the same for the 3rd gear.
i've been trying to do what you said about doing it slowly, it al depends on how fast im going, if I hit the gas pedal as the same time I shift, then I won't feel it.
My car is a 2002 with 88 k on it, and I don't know if the previous driver have changed the clutch.
Old Oct 7, 2007 | 09:26 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
yea it could be the syncros.. but i would change the fluid first
Old Oct 7, 2007 | 11:14 PM
Eddie99's Avatar
If it would be the syncros, how much do you think the dealer is going to take from me? im gonna start changing the fluid though
Old Oct 8, 2007 | 04:22 AM
m R g S r's Avatar
lol a **** ton of $$$
Old Oct 8, 2007 | 05:58 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Wierd problem (m R g S r)
yea it wont be cheap.. your best off putting in some GM syncomesh in there
Old Oct 8, 2007 | 06:00 AM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddie99 &raquo;</TD></TR><TR><TD CLASS="quote">how much do you think the dealer is going to take from me? </TD></TR></TABLE>
this question should be preceeded by "what is the dealer going to take from me, then how much?"
answer: they will take your **** virginity, numerous times until you limp back to your car and realize you can't even sit in the seat without leaving a pool of blood while trying to shift gears to get home
Old Oct 8, 2007 | 06:33 AM
papa5murf's Avatar
Default Re: Wierd problem (GRAF-FITI)
A clutch change isn't cheap and it's a pain in the *** on this car. I would stay clear of the dealer though. They'll probably end up charging you double.
Old Oct 8, 2007 | 11:58 AM
al4t1gbundy's Avatar
Question for you guys .. if its the synchro .. wouldnt it mean every gear would feel this or would only certain gears? I only ask because I sometimes feel this ... and it jumps all over. I mean **** sometimes third, sometimes fourth, sometimes fifth (all not that often) .. then i wouldnt feel it most of the time.
I have an 06 .. could it be the synchros? I am still under warranty ...
Old Oct 8, 2007 | 01:01 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (A08_MThrizzle)
each gear has its own....
Old Oct 8, 2007 | 03:01 PM
scubba's Avatar
Default Re: (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
answer: they will take your **** virginity, numerous times until you limp back to your car and realize you can't even sit in the seat without leaving a pool of blood while trying to shift gears to get home</TD></TR></TABLE>
LOL...
Old Oct 9, 2007 | 08:37 PM
Eddie99's Avatar
Default Re: (scubba)
alright, I went to my Jap friend who is a old Honda mechanic, he has his own shop only for hondas, he has been working with hondas for like 40 years, he is almost 80 years old.
He said to change the clutch, it would be like 3000 dollars. He did not say anything about the syncros, is it in that price range it would cost if you had someone do it for you? he did not say how much it will cost for the syncros.
Old Oct 10, 2007 | 07:03 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (Eddie99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddie99 &raquo;</TD></TR><TR><TD CLASS="quote">alright, I went to my Jap friend who is a old Honda mechanic, he has his own shop only for hondas, he has been working with hondas for like 40 years, he is almost 80 years old.
He said to change the clutch, it would be like 3000 dollars. He did not say anything about the syncros, is it in that price range it would cost if you had someone do it for you? he did not say how much it will cost for the syncros.</TD></TR></TABLE>
your friend isnt much of a friend if he is charging you $3K for a clutch change.... for me to change a clutch on a S2K i charge 350-500 that includes your fluid.. just bring the clutch and ill take care of the rest type thing...
if your changing your clutch look else where
Old Oct 10, 2007 | 07:25 AM
GRAF-FITI's Avatar
* B A N N E D *
are you sure he doesn't mean 3000 YEN?????
Old Oct 10, 2007 | 07:45 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (GRAF-FITI)
are you sure he doesn't mean 3000 YEN?????</TD></TR></TABLE>
thats like $30
Old Oct 10, 2007 | 08:08 AM
GRAF-FITI's Avatar
* B A N N E D *
ha sorry i didn't use my exchange rate calculator...maybe 30,000 yen then....i dunno
Old Oct 11, 2007 | 09:59 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
before you do anything drastic, listen to santos...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">yea it could be the syncros.. but i would change the fluid first </TD></TR></TABLE>
i changed my fluid this past weekend and the car drives like hot fiaaa... seriously each shift is butter... this might be your problem and its a cheap fix... if its not fixed, then go from there... also, how many miles are on the car, what year is it, and when was the last time u changed ur tranny fluid?
Old Oct 11, 2007 | 10:00 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (S2KILLA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KILLA &raquo;</TD></TR><TR><TD CLASS="quote">before you do anything drastic, listen to santos...
i changed my fluid this past weekend and the car drives like hot fiaaa... seriously each shift is butter... this might be your problem and its a cheap fix... if its not fixed, then go from there... also, how many miles are on the car, what year is it, and when was the last time u changed ur tranny fluid?</TD></TR></TABLE>
Old Oct 11, 2007 | 07:55 PM
mugenadict's Avatar
In this back water town the dealers will only install a rebuilt transmission $1200 I think they are all incompetent.
Old Oct 11, 2007 | 09:16 PM
Eddie99's Avatar
Default Re: Wierd problem (mugenadict)
Ok, well I am going to change the tranny fluid first, what tranny fluid should I put in though? the car is a 2002 with 88 k miles on it.
I am not so good at doing it myself either so I am thinking about going to Jiffy lube, or someone who can do it for me who knows cars.
Old Oct 11, 2007 | 09:19 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Honda MTF or GM syncomesh.......
Old Oct 11, 2007 | 09:51 PM
sep's Avatar
sep
I have some problems doing my 5th to 6th shift, it sometimes tries to force me back into 4th.
Is this a synchro issue or the notchiness of the tranny?
I have a 2001 ap1 with 30k miles on it.
Old Oct 12, 2007 | 09:51 AM
Eddie99's Avatar
Default Re: (sep)
alright, I went to Jiffy lube to get my tranny fluid changed. But they said that the dealer is the only one who can change it because it is a special tranny fluid thats needed.
And **** if I go to the dealer, I will have to pay alot more than I should, everyone knows that. If you guys don't change the fluid yourself, where do you go? or am I the only one who need help with this?
I live in CA, Santa monica btw
Old Oct 16, 2007 | 01:22 PM
Cant you put like royal purple in your tranny?
B and B
19
Oct 29, 2005 09:54 PM
zracer240
Jul 21, 2005 12:15 AM
rIceNOodles
Jan 26, 2005 01:01 PM
4DRmafia
Jul 8, 2004 08:36 PM
