shifter play - in and out of gear
shifter just doesnt feel crisp...i was thinking of putting some poly bushings on the shifter. would that help with the smoothness and directness of shifts and is it easy or hard to do by yourself?
thanks
thanks
jacup the car. take out like 3 bolts. relpace the factory bushings with polyurethane ones . 15 min and youre done.
USE WD 40 to make things easier.
at the jetties fishin'
Re: (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 »</TD></TR><TR><TD CLASS="quote">jacup the car. take out like 3 bolts. relpace the factory bushings with polyurethane ones . 15 min and youre done.
USE WD 40 to make things easier.</TD></TR></TABLE>
yep, only reason you'd need to take console out was if you were swapping for a short throw shifter also. which is nice too...
and a cheap ebay piece is just as good as those $100+ name brands imo...
Re: (stackz)
cool thanks guys. does anyone have a pic of the shifter bushings from under the car? so i can locate them...ive only worked under the car afew times for oil and ish like that. A pic would help me get a visual. thanks alot
