s40 transmission
talks to himself
Re: s40 transmission
Yes, I would recommend removing the countershaft from the case.
You'll need to remove the revers gear, shift fork holder, and then the shift forks with the main shaft and counter shaft as an assembly.
Those bearings are pressed on lightly so they'll come off easily. If not, rent a bearing puller tool from a parts store. Replace the bearing in the clutch side case as well. And make sure to stake it into place. There's a great write-up on another honda site that shows exactly what to do.
talks to himself
One reason to pull the shafts is to be able to inspect all the bearings.
N.A.R. has some good pics. Some of mine are here: https://honda-tech.com/forums/showpo...postcount=1426
I never narc'd on nobody!
Input shaft bearings and I aren't friends. One came out in three different pieces, the other one...well, the outer race came out. The ball bearings were mostly disintegrated, and the ones left were welded together...and the inner race, well I just left it in the casing when I sold it.
talks to himself
If you can't get it off with tapping the shaft onto a 2x4 you could go for either of the following pullers:
http://www.princessauto.com/pal/en/P...-Set/8160483.p
or
http://www.princessauto.com/pal/en/P...ller/8045983.p
or
so i used a gear puller and i took it off and replaced it everything went good.
i think hahaha so then i put the case on and everything. And i cant get the pin thingy to get in the groove and i tightened two bolts from opposite sides. To bring on down a little still doesn't want to snap in so i got a rubber mallet and hit the shaft a bit to see if it would move up still nothing any ideas maybe i put it on wrong ???
(ill be embarrassed to say how i messed up that bearing up lets just say young and stupid hhaha )
You have to spread that ring REAAALLLY wide open and it will slide down a little onto the shaft. You will know it is partly on the shaft because it won't close to what you see now, it will stay pretty wide open. Then you flip the case over and lightly drop it on a piece of wood and you will here it snap into place.
If you are using the proper anaerobic gasket maker (hondabond or TheRightStuff grey) you only have 5 minutes after putting the bead on to get that case closed up. After that you have to clean the goop off, place a new bead and try again.
The hardest part I found was opening the clip enough to get it started on the shaft.
Snap ring pliers came in handy but still was tricky.
Good luck.
Even though, when I look at your pic, it looks like it's started... The ends are pretty wide open. Have you tried turning the case upside down and lightly dropping it on a chunk of 2x4 or 4x4 to see if it clicks into place?
Good luck.
Good luck.
Good luck.
Thanks again for the help
The Red and Blue is the standard old RTV and is not Anaerobic. You might experience case leakage down the road, might take a couple of years.
Auto manufacturers switched to the anaerobic gasket makers quite a few years ago do to it's success rate over regular RTV. Regular RTV doesn't always maintain it's seal for the long haul.
If you do experience a leak, look for Permatex "The Right Stuff" grey. There is a black but that is supposed to be for domestics. Not really sure what or if there is a difference between the grey and black "The Right Stuff" being domestics use aluminum heads and blocks etc now a days. But it will provide you a seal that last the duration of your tranny.
Cheers.
Cheers.
Cheers.
Cheers.
Thanks agian for the tip
prelude182
08-03-2009 05:53 PM
Wes V
22
10-25-2003 12:51 PM
