B16A turbo vs B18B turbo?
Ok I was thinking about this today:
Say you have the same car, same Turbo kit, same boost, which setup would win in the 1/4 mile? Which setup would you prefer and why?
My initial thought was that the B18B would win because of the torque and displacement advantage, but on the other hand, the B16 has the better top end with the 8000 rpm redline. I couldn't come to a conclusion on my own so I decided to ask you guys! Any help is appreciated.
_______
_______
Re: B16A turbo vs B18B turbo? (ej1civic)
even though it has more tq initially, it aint that much more , the b16 has 30 or so more hp already, once the turbo starts spooling and vtec hits along with the gearing being just right , say buh bye.
from what i've heard on the board, if you were to boost both motors, with the same boost, the b16 would win, basically because of its better flowing vtec head. However, because of the low compression of the b18b you could boost higher safer then the b16. Just to note, with higher compression, does'nt mean you can't boost as hard, it just require more tunning. The higher compression ratio that you have, the less ROOM FOR ERROR there is. The lower, the more easilier it is with mistakes and fuel promblems.
Re: B16A turbo vs B18B turbo? (EG(6)SR)
i choose teh b18b1 cuz i got one haha. but its has more tq and will pull harder. what would u say turbo si runs at 8 psi on a drag?i think ls is low 13 to mids with a good driver
Oh, sorry to bring up old garbage! I searched but couldn't find anything conclusive. So the B16 would end up winning? That's really interesting! Thanks for the help guys
Re: B16A turbo vs B18B turbo? (tony1)
Either motor will be strong, and output will depend more on tuning than the base motor. Personally I'd go B18B since its cheaper to get, and cheaper to replace if you blow it up.
Re: B16A turbo vs B18B turbo? (ATXhybrid)
I thought that the B18B was cheaper originally but after calling around it looks like I can get a JDM B16 Sir11 swap for the same price as an LS swap! So now I don't know which engine to buy!
well i have a b16a in a hatch w/ turobnetics t3/t4, @7psi and my buddy has a 94 ex coupe w/ a drag kit also at 7 psi. we havent raced yet, but i think itll be a good run. IMO b16a will take the b18b
Re: B16A turbo vs B18B turbo? (zzZZzzleeperCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zzZZzzleeperCX »</TD></TR><TR><TD CLASS="quote">well i have a b16a in a hatch w/ turobnetics t3/t4, @7psi and my buddy has a 94 ex coupe w/ a drag kit also at 7 psi. we havent raced yet, but i think itll be a good run. </TD></TR></TABLE>
not sure how ityll be a good match...your lighter hatch with a better motor then his d16z6 in a heavier coupe...you should own him bad
