RPM on Freeway
Old 06-05-2006, 04:08 PM
DaveyDelSol's Avatar
Default RPM on Freeway
i got a d16z6 in my 93 si... doin around 65ish on the freeway im up to 3grand... is that normal cuz of the short gears in the Z6 tranny???
Old 06-05-2006, 04:15 PM
FalkenSiR's Avatar
Default Re: RPM on Freeway (DaveyDelSol)
At 60 mph, I'm at 2700 rpm, this is a 95 LX tranny.
Old 06-05-2006, 04:18 PM
ITR EG's Avatar
Default Re: RPM on Freeway (fast95eg8)
at 65mph im at 4k with an ITR trans
Old 06-05-2006, 04:49 PM
sleeper101's Avatar
sounds about right
Old 06-05-2006, 04:57 PM
G2 Speed's Avatar
Default Re: RPM on Freeway (sleeper101)
140 at 4grand ... always
Old 06-05-2006, 05:07 PM
Imperious: Mod of Valor
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveyDelSol &raquo;</TD></TR><TR><TD CLASS="quote">i got a d16z6 in my 93 si... doin around 65ish on the freeway im up to 3grand... is that normal cuz of the short gears in the Z6 tranny???</TD></TR></TABLE>
I have the same motor/tranny, that's about what I'm at.
Old 06-05-2006, 05:11 PM
be professional
Targa250R's Avatar
Yes. 65mph in an EH3 Civic Si and EH6 del Sol Si (0.750:1 5th gear) should be between 3000-3100 RPM.
65mph in an EJ1 Civic EX and EH9 Civic EX (0.702:1 5th gear) should be between 2800-2900 RPM.
The short-geared B-series transmissions turn higher revs than that.
Old 06-05-2006, 05:48 PM
LowSlow93Sol's Avatar
Default Re: RPM on Freeway (Targa250R)
Yeah im up in the 3k-3100 range at 65-70mph....i have a gearing chart for the d16z6 and the b-series motors if anyone wants it....
its at work so youll have to wait untill wednesday..or search.
Old 06-05-2006, 06:23 PM
jdmjaser's Avatar
Default Re: RPM on Freeway (onefast93sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR EG &raquo;</TD></TR><TR><TD CLASS="quote">at 65mph im at 4k with an ITR trans</TD></TR></TABLE>
WOW 65 at 4k..so when your goin 80 your at 5k to 5.5k..??
wit my b16 tranny im at 75mph at 4k or so
Old 06-05-2006, 06:37 PM
ITR EG's Avatar
Default Re: RPM on Freeway (jdmjaser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjaser &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah its pretty annoying on the highway
Old 06-05-2006, 06:43 PM
longuyen88's Avatar
103 is vtec on 5th gear ;-)
Old 06-05-2006, 07:06 PM
hondmywrld's Avatar
Default Re: (longuyen88)
my friend's 94lx have use to be at 3k when he's at 85 but couple weeks ago it keeps raising... started going to like 3k at 80 and 3.2k at 85 and then last week it went to 3.2k at 80 wth? at first i thought it's not going to over drive or something( is there even an over drive?) anyways why is that?
Old 06-05-2006, 07:14 PM
be professional
Targa250R's Avatar
Default Re: (hondmywrld)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondmywrld &raquo;</TD></TR><TR><TD CLASS="quote">my friend's 94lx have use to be at 3k when he's at 85 but couple weeks ago it keeps raising... started going to like 3k at 80 and 3.2k at 85 and then last week it went to 3.2k at 80 wth? at first i thought it's not going to over drive or something( is there even an over drive?) anyways why is that?</TD></TR></TABLE>
Because it's an automatic and the torque convertor locks and unlocks.
Old 06-05-2006, 07:24 PM
FalkenSiR's Avatar
you stole my avatar you thief!
Old 06-05-2006, 07:28 PM
hondmywrld's Avatar
Default Re: (Targa250R)
but it's constantly on gas though.....
Old 06-05-2006, 07:33 PM
nekoabandoned's Avatar
b16 with a ls tranny = 3k at 75
Old 06-05-2006, 07:36 PM
professor poon's Avatar
Default Re: RPM on Freeway (ITR EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR EG &raquo;</TD></TR><TR><TD CLASS="quote">Yeah its pretty annoying on the highway</TD></TR></TABLE>
that's probably because the wheels you are riding on are smaller than the ones the itr tranny was originally designed to run with. Right?
Old 06-05-2006, 07:38 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondmywrld &raquo;</TD></TR><TR><TD CLASS="quote">but it's constantly on gas though.....</TD></TR></TABLE>
Therefore slipping. Or maybe his tire size affects the reading...
Old 06-05-2006, 07:47 PM
be professional
Targa250R's Avatar
Default Re: RPM on Freeway (professor poon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by professor poon &raquo;</TD></TR><TR><TD CLASS="quote">that's probably because the wheels you are riding on are smaller than the ones the itr tranny was originally designed to run with. Right?</TD></TR></TABLE>
Tire size does not affect the speedometer/tachometer rading ratio - it only affects actual ground speed vs. indicated speed.
Old 06-05-2006, 07:51 PM
B7AudiA4's Avatar
automatics are 2700
you're lucky to even be at 3000 at 65 with your tranny
Old 06-05-2006, 08:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">Tire size does not affect the speedometer/tachometer rading ratio - it only affects actual ground speed vs. indicated speed.</TD></TR></TABLE>
True... I'm assuming he has the speedometer accurate now, in which case my previous statement would be true
tei344
Transmission & Drivetrain
13
09-14-2008 04:18 PM
sk3ch
09-14-2006 06:25 PM
spoonsports12
Northeast (Sales)
06-10-2006 10:01 PM
Civiminime87
15
01-07-2005 11:23 PM
fsck3r
10
12-23-2002 03:58 PM
Quick Reply: RPM on Freeway
