Resurfacing Head
Re: Resurfacing Head (D16SohcVtec)
All I did was remove the valvecover, sensors, and distributor. Took it to my machine shop and they did the rest. I believe they pulled out the camshaft so all the valves could be pushed up so they could shave it.
Re: Resurfacing Head (nonvtec92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtec92 »</TD></TR><TR><TD CLASS="quote">All I did was remove the valvecover, sensors, and distributor. Took it to my machine shop and they did the rest. I believe they pulled out the camshaft so all the valves could be pushed up so they could shave it.</TD></TR></TABLE>
I see I was just curious, if you needed to remove the valve seats also. Did you tank your head or do they just clean it really good and give it back to you? I dislike having the idea of little metal shavings floating around.
Remove the dowel pin, remove the rotating valvetrain assembly, and you're set! All the valves will be up high enough to not be in the way. Surface away!
full Circling
03-03-2007 02:25 PM
jaxle
21
10-17-2003 06:31 PM
darrinbrewer
02-09-2003 09:36 AM
