Replaced Distibutor, Still Leaking
Hey all,
Wanted to pose this question to the forum as I am a bit stumped. Completed a full rebuild of my D16Z6 last fall, and always had a small oil leak from the distributor area. Replaced the o-ring and helped a little, but still saw oil leaking down the top of the transmission. This spring when I took the car out of winter hibernation, I replaced the distributor all together after seeing I had oil IN the distributor, indicative of a bad bearing seal. Problem solved right? Nope. Installed new Cardone distributor from RockAuto on Sunday, adjusted and thought I would be all good. Yesterday, I get home from work and pop the hood to see oil leaking out of the stupid thing, from the weep hole and on the cap mating face. Is is coincidence that my brand new distributor is bad? Positive pressure in the top end crossed my mind, but the PCV was replaced with brand new during the rebuild, and the breather on the backside of the motor was fully cleaned out at the same time. Can anyone lend some ideas on what could be the problem? It's driving me nuts. (No CEL's by the way.)
Re: Replaced Distibutor, Still Leaking
"Your car be done." That brand is known for sending out a lot of dud parts. Go back to the store and trade it for another one just like it.
Thank you very much for the reply mk378, I appreciate your insight. I was concerned that someone would say that... I have worked on cars of all types for years, and have never used a Cardone product. I will return it and instead go through my local Advance Auto instead of through RockAuto. Again, thank you for the response.
You may be better off sourcing a used OEM unit and replacing any worn bits. I’m not a huge fan of aftermarket dist, but honestly I’ve personally never used one so, a biased opinion.
I've gotta agree with you, mu experience so far with aftermarket distributors has not been a good one.
Easy fix if your old distributor is leaking from inside, I just done this not too long ago. All you do is replace the o-ring inside the distributor. I believe the part number is BH3888. Take everything out inside the distributor just remember how they go back in, then you’ll see the seal inside. Look up on here on how to guide plenty of info.
When you put the seal in don’t shove it all the way in and bottom it out, instead leave like 1-2mm space.
Ive done this so many times and when I put it all the way in and bottom it out, it always starts to leak, until I found on here where you don’t bottom it out and it’ll seal around the shaft better.
i put my seal in 4mths ago and still no leaks. And I know how annoying that sh*t is too. So really glad I finally got it fixed!!!
Yea bro give it a try, it’s cheaper than $100+. Just know the OEM distributor will last longer than aftermarket. $10 seal is worth saving that OEM distributor.
Wanted to follow-up with everyone that took the time to comment and provide help. I sent back the 2nd distributor from RockAuto (Cardone) and purchased a Carquest distributor from Advance Auto. Installed the Carquest product and the leaking stopped! Problem solved.
