What is nececary to take out when removing a front bumper?
I bought a 2000 hatchback with aftermarket Buddyclub bumpers and i would like to take off the front bumper and swap it with the OEM bumper, I was wondering what i would have to take off in order to get the bumper off.. if anyone has any diagrams or anything itd help alot.
Re: What is nececary to take out when removing a front bumper? (tEhNgUyeN)
Open the hood. There are 5 screws holding the bumper to the frame. Take those out. Then look at where the bumper meets the fenders on each side. 1 screw on each side. If you're taking off the left side turn your wheel all the way to the right, get under there with a screw driver and unscrew it. Repeat for the right side. Then you just pull the bumper off.
Re: What is nececary to take out when removing a front bumper? (nota-ex)
I dont need to take off the headlights nor the grille? / I've found the screws in the wheel well that connects the bumper and fenders but im not sure what 5 screws are connected to the bumpers on top?
Modified by tEhNgUyeN at 9:01 PM 5/19/2005
theyre right by where the latch is to open the hood. all along there, u cant miss them theyre bigger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tEhNgUyeN »</TD></TR><TR><TD CLASS="quote">I dont need to take off the headlights nor the grille? / I've found the screws in the wheel well that connects the bumper and fenders but im not sure what 5 screws are connected to the bumpers on top?</TD></TR></TABLE>
They're not screws. You said 2000, right? Then they should be plastic clips. You pop up the middle part of the clip with a flathead, and then you can wiggle the clips out. Very simple. Also, there will probably be two bolts underneath that you'll have to remove with a socket wrench. Either 10 or 12mm, can't remember exactly, but it's easy enough. Again, pop the hood to remove the clips, remove the wheelwell screws, and remove the underside bolts. The bumper cover will then slide right off.
EDIT--Oh, and don't worry if the clips break. There were at least three clips that broke on my Civic, but they worked fine enough. They only had three "legs" left (if you look at one, you'll see what I mean), but they were usable. But if two of the legs break then you should replace it.
wtf this bumper was installed professionally.. there was only 2 plastic screw things near the bottom of the headlights for the bumper the rest was for the grill, i took out one screw under the wheel well but the bumper doesnt seem to budge, would i also have to jack up my car for the other screws on the bottom?
Screw locations:
1) Where the fender and bumper meet
2) On the top of the bumper beside each headlight
3) 3 or 4 screws on the bottom of the bumper. (You can jack your car up to take these off, or you can get a smaller length screwdriver to remove them)
Re: What is nececary to take out when removing a front bumper? (Built to Spill)
woo thanks guys i got the front bumper off..
anyone wanna get me started on how to take off the back bumper?
Open the trunk and look down. Take all those off. There should be a screw on each side of the bumper where it meets the quarter panel also.
so i open the hatch and just un bolt all the screws and the 2 screws in the wheel wells?
