Removing aftermarket shift knob
Old 02-22-2010, 12:15 AM
White95SiHB's Avatar
Default Removing aftermarket shift ****
When I bought my beater it already came with a shift **** that looks exactly like this:
I removed the allen screws on top as well as the carbon fiber sleeve. But I can't figure out how to remove the rest of the ****. I tried twisting it off but it didn't budge, and I already cut my fingers on the peeling chrome.
Just wondering if anyone here has this **** and can give me some insight on how to remove it.
Old 02-22-2010, 12:26 AM
JdmOdz's Avatar
Default Re: Removing aftermarket shift ****
Good luck
Old 02-22-2010, 12:56 AM
starion88esir's Avatar
If it doesn't twist off, it should be attached via a hex head set screw. Usually they're towards the base. You'll usually have to look close to find them.
Old 02-22-2010, 05:03 AM
318 Curves, 11 miles
Vindicator9000's Avatar
Yeah, even the ones with hex screws just twist on. My guess is that the previous owner got tired of it being loose (as most cheapie aftermarket shiftknobs are in my experience) and probably hit it with some loctite or superglue.
Worst comes to worst, you can always dremel it apart. Or chop off the shifter and order a B&M dual bend to replace it.
Old 02-22-2010, 05:24 AM
MrExclusive's Avatar
Sometimes you just have to really yank on it. Might seem cruel but harmless. Just watch your head on the roof of the car(Memories lol). Unless of course its really super glued on.
Old 02-22-2010, 11:02 AM
vlc92189's Avatar
chop it off and get a skunk2 shifter/**** combo.
Old 02-22-2010, 11:04 AM
Reject Papi
jhammond_82's Avatar
use a pipe wrench?
Old 02-22-2010, 12:25 PM
thumper64's Avatar
dremel tool? What kind of shifter do you have? Maybe it's time to upgrade.
Old 02-22-2010, 01:56 PM
bsmith100's Avatar
Like other people have said, some of the universal type aftermarket shift ***** are held on with 1 or more set screws.
Old 02-22-2010, 02:12 PM
z6htch's Avatar
Break out the Saw Zaw!
Old 02-22-2010, 04:37 PM
ChRiS_p123's Avatar
There might be a collar at the bottom of the **** that unscrews and then there are allen head set screws that secure it to the shifter
Old 02-22-2010, 05:34 PM
importdreamer's Avatar
That's the way my cheapee is. My friend had to sit in the backseat with a pair of vice grips on the shifter in 3rd gear, and kick the **** out of his. Had a bunch of blue **** on the threads.
Old 02-22-2010, 05:37 PM
Reject Papi
i got a 24" pipe wrench that'll get that thing off first try. lol. all you need is some leverage.
joker4096
12
06-12-2006 10:17 PM
jdmxtacy
12-26-2005 07:48 PM
datac99
11-29-2005 04:33 PM
acme
06-16-2003 03:15 PM
joemama
05-24-2001 05:01 PM
Quick Reply: Removing aftermarket shift knob
