rear sway bar for 94 DX sedan
i was just wondering if there are holes for the rear sway bar mounting brackets on the rear crossmember of a 94 DX sedan. quick simple answer here fellas!
Re: rear sway bar for 94 DX sedan (timmy0tool)
yes ,but you have no holes in your lca's. i just purchased a 22mm progressive rear sway bar that doesn't require you to swap lca's because it mounts using the lower strut bolt. suspension techniques(sp?) also makes one.
Re: (timmy0tool)
im not sure, but i dont think it's safe to do that. i actually just read a post where someone asked this and was advised to just swap the lca's.
i just put a rear sway bar on my 93 ex off a 98 gsr teg. I had the mounting holes on the subframe already but none on the lcas so i bought some omnipower control arms
DpSyChO
38
04-10-2013 12:51 PM
