rear sway bar for 94 DX sedan
i was just wondering if there are holes for the rear sway bar mounting brackets on the rear crossmember of a 94 DX sedan. quick simple answer here fellas! https://honda-tech.com/forums/images/smilies/emthup.gif
Re: rear sway bar for 94 DX sedan (timmy0tool)
yes ,but you have no holes in your lca's. i just purchased a 22mm progressive rear sway bar that doesn't require you to swap lca's because it mounts using the lower strut bolt. suspension techniques(sp?) also makes one.
isn't there a location for the hole though? can i drill it on?
Re: (timmy0tool)
im not sure, but i dont think it's safe to do that. i actually just read a post where someone asked this and was advised to just swap the lca's.
i just put a rear sway bar on my 93 ex off a 98 gsr teg. I had the mounting holes on the subframe already but none on the lcas so i bought some omnipower control arms https://honda-tech.com/forums/images/smilies/emthup.gif
yeah it seems you can't just drill out those holes. the arms look completely different as seem below:
http://www.hondaautomotiveparts.com/...13sr40_j16.gif |
