rear mount B swap into delsol
wich T bracket to use for B swap into delsol EK
hi there, i wish i could have some help, i know the part # are not the same for the rear T bracket from si 99-00 and dohc vtec 96-97 delsol!
but are they usable both for b18 swap into a delsol?
my girlfriend have a 96 delsol and it's look like it's use 96-00 engine mount like a civic! but i dont know if the rear T bracket is switchable from delsol sir 96-97 and civic si 99-00 ?
cant find this information into Swap sticky!! only see that everybody use the civic si 99-00 mount
so i only need to find a si 99-00 T bracket to swap her a little b18 or should i really need a delsol 96-97 dohc vtec one?
Re: wich T bracket to use for B swap into delsol EK (mcleod)
noooooooo.. don't get a 99-00 Si T bracket get a 94-01 Integra T bracket and you'll be good
nope believe it or not they use the same mounts as 93-95 del sols, go compare them and you will see I am right, the easy way to tell is that the 96-00 EK has a driverside oil filled mount and your 96-97 del sol will not. It will have the eg style.
Re: wich T bracket to use for B swap into delsol EK (USDMCIVICHATCH)
yeah! i have finished the b series installation, and was in need to use the integra one rather then a civic si 99-00 like what i was thinking
not very good since i was unable to find the color match for my obd2b harness to fit a obd2a dizzy!
so i have modded the d16y8 dizzy to fit the head till i found my answer!
i do have 9 wire on the b16a obd2a distributor and 8 wire on my obd2b harness!
and they dont seem to be color match!
should found a diagram
why do you have an obd2b harness? 96-97 del sols are obd2a. also obd2a and obd2b b series dizzys are the same thing plug and play
ANGELIQUE
03-15-2005 12:25 PM
pennies_hatchie
19
09-09-2003 06:48 AM
