racking pinion swap???
Anyone know or have experience swaping out racking pinions from EJ1 to a DC2?? is it really complicated? can it be done without taking out motor?? my ball bearings for steering is out leaking lubricate. It also makes noises when I step on the brakes and hit bumps. I know its not the brakes, I just change rotor and pads.. anyones help would really be apreciated.
Re: racking pinion swap??? (chinoty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chinoty »</TD></TR><TR><TD CLASS="quote"> It also makes noises when I step on the brakes and hit bumps. </TD></TR></TABLE>
That would be a sign of the bushings on the rack being bad, also I'm not sure on the year but if you are switching to a non power steering one or vice versa, last I read you do have to modify it to fit.
I would basically advise you to get the one for the car, if you really feel like its bad. What ball bearings are you talking about ?
Re: racking pinion swap??? (RCautoworks)
It is the ball bearing on the driver side that controls the steering, I can see the grease splatter on the shocks and underbody. The reason why I ask if it can be done was because I have an extra Racking Pinion laying around. Both mines and the GSR has the PS. So I dont know if it would fit or not...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chinoty »</TD></TR><TR><TD CLASS="quote">It is the ball bearing on the driver side that controls the steering, I can see the grease splatter on the shocks and underbody. The reason why I ask if it can be done was because I have an extra Racking Pinion laying around. Both mines and the GSR has the PS. So I dont know if it would fit or not... </TD></TR></TABLE>
Should fit up fine, if your sure its that grease and not axle grease, so ahead and swap it out
beav
10
12-04-2008 02:03 PM
schueytenten
09-05-2008 09:37 PM
.Thomas
02-18-2007 03:56 PM
eda6
11-25-2006 10:27 AM
the soL that could
Suspension & Brakes
02-14-2006 02:18 PM
