quick question
Re: quick question (tx6stringer)
I wann kill it cuz mine is backwards! whenever my keys ARENT in the ignition it beeps and when they are in it doesnt. I just bought the car and that how it was.
Re: quick question (ek guy)
or you can clip the wire to the door, never done it before, should work, or take the switch out and tape it closed, or wire a switch to it and keep it closed. I have not done any of this so use these ideas at your own risk
Re: quick question (medside)
hey thanks for the ideas medside but I also have keyless entry alarm system and Im pretty sure that screwing with the door switch would screw that up. I got a wiring diagram and Im pretty sure theres a relay for that beeping noise but I dont know wat its called. if anyone knows wat that beeping noise is called or knows how to kill it. HELP ME OUT! I CANT STAND THIS DAMN BEEPING!
blue/white 18 ga wire. Pop open your steering column cover and it's close to the ignition wires.
test though. when you stick the key in it should go to GROUND. that is the wire and just cut it.
hope my explanation was pretty easy to understand. i don't make sense sometimes.
lmk if that works
lmk if that works
blinger
08-10-2007 10:43 AM
LaOstha
12-24-2006 04:48 PM
