Powers Door locks suddenly quit working!!
Old Feb 21, 2006 | 06:33 AM
Wilky's Avatar
Default Powers Door locks suddenly quit working!!
I got out of my 97 civic LX sedan this morning and went to lock the doors with the pwr switch and nothing happened. Is this a common failure? Could it possibly be just a wire having come unsoldered? Any input welcome. I know it's a cushy feature, but I like my pwr door locks - they come in useful of a 4-door.
Old Feb 21, 2006 | 07:20 AM
Lewdin' Incognito's Avatar
Default Re: Powers Door locks suddenly quit working!! (Wilky)
Fuse, switch, wire.
I don't have Civic-specific input, but that's where I would look.
Old Feb 21, 2006 | 09:49 AM
Wilky's Avatar
Default Re: Powers Door locks suddenly quit working!! (Lewdin' Incognito)
Anyone know which fuse operates the door switch and if there is anything else on the same fuse?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewdin’ Incognito &raquo;</TD></TR><TR><TD CLASS="quote">Fuse, switch, wire.</TD></TR></TABLE>
What do you mean by "wire." Is is what I already stated - possible solder loosening?
Old Feb 21, 2006 | 12:13 PM
By "wire" I meant anything that could involve the wiring:
-bad connection (yes - solder/terminal)
-broken/pinched
-short
-pulled off
etc...
EDIT: Checking continuity with a multimeter should be able to narrow your search down.
Old Feb 21, 2006 | 04:55 PM
Wilky's Avatar
I will get on these checks soon and post up what I find.
Is this a common problem? I know someone else has to have dealt with the same thing.
Old Feb 21, 2006 | 06:44 PM
lobudgetr's Avatar
Check to see if the plug on the door came loose. It plugs in to the front of the door.
Old Feb 25, 2006 | 07:45 AM
travelor101's Avatar
Default Re: Powers Door locks suddenly quit working!! (lobudgetr)
I learned a little bit installing my own set into a an 93si hatch. The first try was JDM, didn't know the polarity is reversed and blew a ton of fuzes. Also leanred that if one connection is lose for the window control (driver or passenger side), the other side will not work. "Lewdin’ Incognito" was right about "Fuse, switch, wire." Order and all... wish you luck.
Old Feb 25, 2006 | 09:01 AM
slomofo's Avatar
GDD Member
Do you have intermittent wipers by chance?
Old Mar 8, 2006 | 11:00 AM
Wilky's Avatar
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Do you have intermittent wipers by chance?</TD></TR></TABLE>
If by that you mean the speed is adjustable, then yes.
I checked the fuse today, even switched it out with a known good fuse - still nothing. I took the handle/switch panel off the door and looked at the terminal - it is a plug, not soldered. Looked fine. I don't know where to go from there.
BTW, I also checked the harness that runs from fender to door, and it looked good - there is a cover over it which was intact at both places. I assume that means it's all cool underneath.
What should I look at next?
Old Mar 15, 2006 | 08:42 AM
slomofo's Avatar
GDD Member
Sounds kind of strange, but try turning the key on with engine off, then move your intermittent wiper control through it's different speeds, then start the car and see if the locks work.
Old Mar 15, 2006 | 08:57 AM
Wilky's Avatar
Will do this evening. I'll get back to ya.
johnboy1313
Honda Civic (2001 - 2005)
13
Aug 10, 2014 01:46 PM
jspeccrx91
Feb 1, 2010 03:01 PM
RichardGSR411
Nov 4, 2007 05:58 AM
thatasiankidtony
Audio / Security / Video
Nov 7, 2006 02:18 PM
