help with wiring!
help with wiring!
a little background...car is a 2000 civic si,fully built NA motor as of now makeing 179 whp...it was stolen and amongst other parts taken the theives CUT my ecu out instead of unlpugging it.
so far i have another complete engine harness that will contain plugs B and C i belive...the other ecu plug is located on the cabin harness...i have a conversion harness that i am going to cut to use (going to splice my cut cabin harness into it)
NOW FOR MY QUESTION-on the engine harness there is a third plug that is bright green that is supposed to plug into a part on the cabin harness...since the end of my cabin harness has been chopped off i need to know what wires should be pinned into this green coupler comming off of the engine harness. if someone could tell me which sensor they belong to and wire colors that would be helpful...all i can find is katmann ecu pinout which does not include this green plug that goes into the cabin harness.
Re: help with wiring!
goodluck, typically no one has, or cares about that plug since its never needed for pinning.... my suggestion is make a friend at a honda dealer, and politely ask them for a pinout
nello a.
12-24-2008 12:20 AM
