question on my 00 si headlights
Old 06-30-2005, 01:41 PM
thelonerangers's Avatar
Default question on my 00 si headlights
on the outside where its plastic i assume its like permantly dirty or like faded or something. is there something i can do to make them look new?
Old 06-30-2005, 02:44 PM
underb00steg6's Avatar
Default Re: question on my 00 si headlights (ian22)
sand paper 2000 grit.....something really fine
Old 06-30-2005, 03:47 PM
96turboek's Avatar
you could try Eagle one "Never dull" and see if that works.
Old 06-30-2005, 05:16 PM
insomniac791's Avatar
polishing compound and a buffer worked on mine!
Old 06-30-2005, 05:24 PM
98b18black's Avatar
Default Re: question on my 00 si headlights (underb00steg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 &raquo;</TD></TR><TR><TD CLASS="quote">sand paper 2000 grit.....something really fine </TD></TR></TABLE>
....works great....
Old 06-30-2005, 05:30 PM
Farts in the shower
The_Todd's Avatar
Get some 1500 grit and 2000 grit wet sandpaper, some 3m rubbing compound and some plastix (by meguiars) and clean those headlights up.
Start with the 1500 and use plenty of water and rinse the sandpaper alot. Then when you feel the 1500 is good and done move on to the 2000 and repeat the process. After you get done rinse everything off very well and allow it to dry completely. After the headlights have dried apply some rubbing compound like you do wax and let it haze up then buff it out. Then apply the plastix the way you did the rubbing compound and whiola...new looking headlights.
Doing this will also reduce the pits in the headlights and take out any yellowish or cloudiness in the headlight.
Old 06-30-2005, 06:21 PM
KingElli's Avatar
go to home depot or lowes and try plastic polish.
Jap_Spec_Imports
03-15-2009 05:17 PM
Jap_Spec_Imports
11-16-2008 12:16 PM
93dagsr
09-21-2007 06:16 PM
ap716
07-29-2006 03:10 AM
Vero
03-12-2004 07:04 PM
Quick Reply: question on my 00 si headlights
