Question on gsr rear disc install
There is only 1 wire from my e-brake cable from my e-brake handle. However there is 2 wires from the rear disc. How would I go about to install this?
um, did you disconnect the union where the two wires attach to your e-brake handle?
because the two wires come up, hook into this metal thinger, then the one wire attaches to the handle
did you pay attention when you removed it?
Re: Question on gsr rear disc install (blue_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">um, did you disconnect the union where the two wires attach to your e-brake handle?
did you pay attention when you removed it?</TD></TR></TABLE>
guess i'll have to take a look underneath. i let you know later if it works out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue_hatch »</TD></TR><TR><TD CLASS="quote">theres only one cable that hooks up to the e-brake currently... how am i suppose to hook up the 2 cables to it? </TD></TR></TABLE>
That's not good...
The cables connect to #3
That's not good...
Re: Question on gsr rear disc install (BlueIntegraBoy)
Okay guys i got it working. Now my next question... will the gsr hub bearing fit on my si trailing arm. they seem to be the exact size?
JDM_SOHC
03-12-2007 04:25 PM
