Firewall question
Old 05-16-2003, 12:09 PM
Rhythm Racer's Avatar
Default Firewall question
I need to run some wires through my fire wall , where is an opening or do i have to drill???
Old 05-16-2003, 12:11 PM
Spade's Avatar
Default Re: Firewall question (Rhythm Racer)
There is openings all over, check under the glovebox.
Old 05-16-2003, 12:19 PM
Default Re: Firewall question (Spade)
Thanks !!!!
Old 05-16-2003, 12:22 PM
=GAME='s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">There is openings all over, check under the glovebox.</TD></TR></TABLE>
or right behind the battery under the hood.
Old 05-16-2003, 11:34 PM
built562's Avatar
Default Re: Firewall question (GAMEOVER 1.8)
try never to drill the firewall because it will leave exposed metal to rust and the edges will be sharp and the wires will rub on the edge with normal engine movments cause the wire to cut or short.
there are a few openings by the throttle cable right under the brake master cylinder.
Old 05-16-2003, 11:37 PM
SikofFalln's Avatar
Default Re: Firewall question (akumaracer)
IF you don't have cruise there is a perfect opening right next to the throtle cable.
Old 05-17-2003, 12:14 AM
ridiculous's Avatar
Default Re: Firewall question (BseriesPWR)
i tried to feed some wires through the openings in my firewall, but it seems that there is some metal "wall" in the way. i pulled out the rubber plug, now i see white plastic around the hole, but i cant get wires through, what the hell?
f2m0u5
04-24-2006 09:52 PM
Mordeki
Audio / Security / Video
03-21-2005 04:05 PM
mingbling96
01-19-2005 08:52 PM
machinehead
01-08-2004 02:19 PM
NSX Bob
05-03-2003 01:24 PM
Quick Reply: Firewall question
