Question about clutch engagment
I just got done putting in my swap and I installed an Exedy clutch and flywheel. When I started to drive the car i noticed that the clutch doesnt engage until the pedal is almost completely up. Anyway I can fix this?
Re: Question about clutch engagment (Mista Bone)
Mine does that also. I have a Clutchnet StageII.
You can adjust the clutch engagement pedal with a screw on the master cylinder.
The high engagement is actually better since it helps to prevent missed shifts. I would leave it alone.
Re: Question about clutch engagment (maxim)
thanks
New User
Re: Question about clutch engagment (EKen9)
Did you bleed the system correctly? It sounds as if you didnt bleed the clutch system good enough. And this is a upgrade clutch correct?
[Modified by lshatchturbo, 12:14 PM 7/4/2002]
Stonage07
03-06-2017 11:48 AM
supersilverdc2
Transmission & Drivetrain
11
01-16-2014 12:45 PM
