PROJECTORS ?
PROJECTORS ?
I HAVE A 93 EX AND BOUGHT SOME PROJECTORS FROM ADVANCE IMPORTS BUT THE LIGHT IS NOT BRIGHT ENOUGH THEY SENT ME SOME WEIRD WIRE WITH IT I DONT KNOW WHAT IT IS DO U GUYS HAVE ANY IDEA WHAT IT MIGHT BE FOR AND HOW CAN I MAKE THE LIGHTS BRIGHTER
Re: PROJECTORS ? (rkn527)
WHY ARE YOU YELLING!!
anyways, that extra wiring that came with should be there so you can wire both the high and low beams to light up at the same time. At least thats what it was for on my denji projectors, I never took on the task of wiring them up though so I don't know how to do it.
Re: PROJECTORS ? (AztecEJ)
He is right, the extra wire is to intenconnect the 2 lights so you can have high/low on at same time but thats ghey cause you dont often drive with your h/b on anwyays.
Want a better brighter light?
1. get a better headlight
2. buy better bulbs
3. Get a hid kit for em hoes
good luck.
p.s: Dont buy cheap aftermarket bulbs that say they are really bright cauze they are often not and will fry your wiring by drawing too much of a load.
Get a good piaa bulb!
2. buy better bulbs
good luck.
Re: PROJECTORS ? (B18C GSR CIVIC)
http://www.motionr.com 6000K's These are the GOD of all bulbs!!! and are cheaper then the Piaa's
Re: PROJECTORS ? (civiksiracer1)
projectors always have a low light or sumthing like that, hook up that extra wiring it helps make them brighter, i ran my projectors off the stock wiring and they were so dim, but when i used the wiring i got with it, it helped out alot... need help about wiring them up just P.M. me, ill help you out
..<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AztecEJ »</TD></TR><TR><TD CLASS="quote">WHY ARE YOU YELLING!!
anyways, that extra wiring that came with should be there so you can wire both the high and low beams to light up at the same time. At least thats what it was for on my denji projectors, I never took on the task of wiring them up though so I don't know how to do it.</TD></TR></TABLE>
hah .do everybody these days like to CAPS LOCK..
FotoGenetix
04-03-2007 11:39 AM
RedHackBatch
07-06-2004 09:39 PM
