fast blinking signal light...
my corner light fell off on the highway and the piece that holds the bulb somehow came off with it =/....im using my friends piece that holds the bulb and now it blinks twice as fast as it should. is there ne way to fix this?
Imperious: Mod of Valor
Re: fast blinking signal light... (xFlipNotiKx)
Same thing happened to me when I was switching out bulbs. One of the wires fell out from the connector. I think it's the green wire, but I'm not exactly sure, just check all the wires, make sure there pushed in good.
Re: fast blinking signal light... (SiKid86)
it would also blink faster if u used a 1156 bulb into a 1157 bulb socket.. but that would just be retarded, but **** happens
Re: (RedHackBatch)
did it rip out some of ur wiring? just go to a junkyard and cut some wire with the socket and hook it up to ur loose wires. if not u can pull teh connectors off the socket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiKid86 »</TD></TR><TR><TD CLASS="quote">your lights blink faster when there is a short in the wiring.... Like a blub being busted or a wire loose. Just fix it.</TD></TR></TABLE>
Re: (RedHackBatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedHackBatch »</TD></TR><TR><TD CLASS="quote">thanks its most likely the wiring. btw does ne one know where to get that piece that holds up the bulbs??</TD></TR></TABLE>
hey jeff, there are three civics i found at a junkyard. i remember they have the corner assembly that you can steal lol.
