problems with lsv swap
We just did a LS vtec swap into a 95 Int GSR. We didnt touch any of the wiring on the gsr harness and we finished up the motor. Whats trippin me out is that the car never through a o2 code before but now its throughing a o2 light as soon as you turn the key in the on poisition. We even changed the o2 to a brand new one and it still throughs code, (code 1). The ecu we are using is a obd1 p28 with a skunk program and the wiring is all original. The car does have a vafc installed but the wiring is all correct. let me know what you guys think... need help asap. thanks...
Re: problems with lsv swap (Pho Real)
sux huh... well what could cause a o2 code to come on other than the o2 not being hooked up. what do i need to check for. could a bad ground cause just an o2 code or would it cause more codes than that??, let me know... late
93grayeg
10
07-30-2011 11:35 AM
