Stripped struts
Stripped struts
Damn, tried to put on a strut bar today in front and the nuts that need to come off to put this on are stripped, not rounded, strippped. I turned one for about 5 min. and it spun and spun, but didnt move up or down like it should have. How can I get these off? Bolt Cracker? Air Hammer?
Thanks
Dan
Thanks
Dan
Re: Stripped struts (turbotime)
i would try a bolt craker first..not to long ago i used a pipe wrench to get some stripped bolts off and that actually worked so just try things..anything goodluck
adaM
adaM
Re: Stripped struts (FifthGearOnline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FifthGearOnline »</TD></TR><TR><TD CLASS="quote">Craftsman Worn Bolt and Nut Remover
works like you wouldnt f'in believe!!!!!!!!!!!!!!!!!!!</TD></TR></TABLE>
I can second that
I can second that
will the craftsman work for this though? I can grip the bolt and turn it, but the thread are f*ct so it just keeps spinnin and spinnin. Let me know, becuase if so im going to sears tomorrow to get me one.
Re: (turbotime)
Are you talking about the bolt on TOP of the strut, or the two on the side? The bolt on TOP of the strut wont come off because the whole thing spins. You need to use an allen wrench to hold the center steady so it doesn't spin and then take the nut off. Alot of times, the allen wrench will strip so your best bet is hit it with an impact.
Solbros Owns Me
Re: (menkio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio »</TD></TR><TR><TD CLASS="quote">umm... why would you spend 5 mins turning a striped bolt.. </TD></TR></TABLE>
true
true
Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
true</TD></TR></TABLE> Ouch....
