problem...please help
Old Jun 4, 2002 | 09:28 PM
J 9CIV9's Avatar
Default problem...please help
OK, a few months ago, I installed an MSD SCI ignition in my 1999 Civic EX, it worked fine until i hooked up the MSD cap and coil about a month later....AS SOON as I did this, my engine started sputtering real bad, it was almost like it was firing on only 3 cylinders, and every now and then the fourth kicks in...my car has half the power it used to, and it's louder than usual....So, I hooked the stock distributor cap and stock ignition coil up, and took out my SCI...and it still did the same thing..I checked the fuel injectors, the spark plugs, the plug wires, and I reset my ecu, still nothing changed..... I even took all my mods off exept my exhaust, fpr, fuel rail, pulleys, and JET ECU, all of which I had on way before this problem started...anyone know what this could be? Thanks in advance for your help and sorry for the long post...
[Modified by J 9CIV9, 6:29 AM 6/5/2002]
95blackEG
Dec 24, 2008 07:59 PM
92lstcvc
Mar 19, 2006 07:00 AM
92lstcvc
Mar 18, 2006 09:09 PM
gottagofaster
Oct 21, 2005 11:58 PM
