Need 5 lug help for s2000 wheels.
wasup guys, i want to do a 5 lug and got a good offer on some s2000 wheels. Will they fit if i do a 5 lug conversion? thanks.
Guest
Posts: n/a
Re: Need 5 lug help for s2000 wheels. (SilverCivic2k)
yes and no.
yes the should have the same lug pattern. But the offset will not let it fit the front. So you can drive around like a stunna have have 17's in the rear, and 14" steelies up.
[Modified by YodaIsGod, 11:52 PM 6/4/2002]
ok 2 conflicting answers first guy says only rears fit second says only use front rims. So which is it? thanks and do you have pics of the s2000's on your teg? I don't know if it is gonna look good on a civic.
I think they mean only the front two s2000 wheels will fit because the rear s2000 wheels are wider then the front. If you put the rear s2000 wheel on then the tire and rim will stick out from your fender or quarter panel.
ocyrus411
06-22-2009 10:23 PM
