Problem with my swap and need help asap.
I just swapped in a ls vtec. The engine fires up but will not idle when I take my foot off of the clutch. If I start it I have to keep on foot on the gas and one on the clutch. If I remove either then the car just die. What could that be?
Also whenever I rev up the car lags.
thanks
drew-
thanks
drew-
Re: Problem with my swap and need help asap. (drewlee)
sounds like a few problems, are you throwing any CEL's?? if so, which ones. Also check your clutch fluid, and rebleed the line.
Unceasing Measure
A massive vacuum leak might be a contributing factor too, so check that out while you're under the hood making sure everything's plugged in and fluids aren't splashing all over the car.
Re: (Slammd Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammd Sol »</TD></TR><TR><TD CLASS="quote">are u using the correct ECU?</TD></TR></TABLE>
I am using a p28 with a 92 civic si wire harness. It is throwing a cel, but I dont know how to check those.
thanks
drew-
thanks
drew-
dominicanboi215
01-07-2009 03:27 PM
chinkyEyez
12
08-20-2004 11:58 AM
