d15b problems need help asap
i have a jdm d15b with a p28 ecu and my problem is the car runs like crap when u start it up it idles fine for a minute or so and when it warms up the car almost sounds like its missing then i went ahead and took it for a drive and when i took off i noticed that the revs were struggling to get up when i finally let the clutch fully engage the rpms dropped to round 500 and i punched it and they just stayed there even at full throttle then they started to climb very slowly wtf is going on with my car i figured it was timing but i have timed it many times and still the same thing any help would be great
Re: d15b problems need help asap (RFd15bhatch)
Did you just get the engine? After you check the connections, check your valve clearance and compression check your engine. You may have a serious problem with your head gasket...just a thought though.
