problem with ebay fogs
there is an extra brown male connector that has a fuse on the same wire. the switch has power to it because the light turns on. the relay clicks when I press the switch. the lights dont turn on...man im mad. I was thinking if it was better to just direct wire it. opinions?
Re: problem with ebay fogs
you know you have an eg when... haha.. every damn civic in america has those fog lights and none of them work or are even actually wired lol
i don't know if i have ebay ones, but i sorted it out with a new relay and the fog switch i had in dash.. and i just had only the wires from the foglight bulbs.. so just try to use your head or google the wiring of some random foglights!!!
this might help, https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/egay-knock-off-fog-light-wiring-help-2716028/ . its a while since i done my ebay ones but i just searched on the net some
yeah im thinking about just wiring direct i know the relay is messed up and the wiring is kinds faulty. oh well at least they look nice.haha
http://www.passwordjdm.com/Install_N...tall_Notes.pdf
This might help, it's what I used when I installed mine.
It was a while ago and I don't remember what wires went where really. Don't remember a brown plug.
those looks like the honda instructions, which i did use. there is just this one last brown plug which i have no idea where to plug into. ill get some pics up in a bit.
i have a setup similar to that but mine did not come with anything to the fuse box at all and they work by power from the battery and ground with a harness from each fog back up to the button to the switch on the steering column
That plug DOES go into the fuse box as well. One goes to the BATT plug and the other goes to headlight switch one.
This guide seems to have the same wiring as you so follow this ---> http://www.clubcivic.com/board/showthread.php?t=66852
MGBej1503
11-08-2011 11:42 AM
born2sleep13
15
10-26-2011 06:40 AM
SinsEvil666
11-09-2007 01:10 PM
