Ebay Foglights.
Ebay Foglights.
Hey guys,
I bought some ebay foglights a while back for my 99 civic sedan and have been away for school. I wanted to install them this winter break but realized that they didn't come with a foglight switch. So I picked up an oem foglight switch but it doesn't fit the cheap ebay harness. Anyone know where I can find the ebay switch or any suggestions? Thanks in advance.
Re: Ebay Foglights.
Thanks for the response knoxcivic. If i wire them to my parking lights when will they work? is it only when i turn on my parking lights?
Re: Ebay Foglights.
go to ur local junk yard and pull the plug off a 94 accord threw w.e year but has to be same body style and wire it up
heres the thread
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bdiy%5D-how-use-oem-switch-your-99-00-aftermarket-fog-lights-2246130/
heres the thread
Re: Ebay Foglights.
i wired mine up to my parking lights
on my old em1 , and they worked
fine...but also i know they have
the switch on password jdm if that
helps you out at all.
Re: Ebay Foglights.
Sorry, not tryin to thread jack but how exactly do you wire them into your corner lights?
do i still need to use a relay and a fuse? my harness fried, and i rewired it but forgot the fuse amp i need.
btw they're depo fogs for an ej2 or "eg"
Re: Ebay Foglights.
yeas you need to run a relay and a fuse, ts to much power to draw off of just your parking light hot wire, local auto parts stores sell basic 4 pin relays for pretty cheap and just run a 10amp fuse one the power wire. if you have common knowlegde of auto/elec. this should be a breeze. good luck
Re: Ebay Foglights.
well, i still have have the harness, relay, inline fuse, and switch. when i went to rewire everything, only one or two of the wires in between the two fogs werer pretty much fried. the rest weren't damamged to bad, but were replaced anyways.
would i keep everything in the same locations? or how/where would i be connecting the wiring. i can do little asic common sense things with wiring, but its deff not my forte. im better at turning wrenches
Re: Ebay Foglights.
what i did is got a rocker switch from oznium.com and wired the fogs into my clock/ radio so i have a seperate switch instead of the fogs turning on everytime i turn my lights on
Re: Ebay Foglights.
What i did was just buy a on/off switch from my local autopart store and wire that up.
integlspwr2k
11
01-21-2010 12:39 PM
SinsEvil666
11-09-2007 01:10 PM
LoveOfMoney
10
06-24-2005 06:52 PM
