DRIVER SIDE WINDOW ISSUE
Old Jun 28, 2007 | 09:30 AM
g0tgot's Avatar
Default DRIVER SIDE WINDOW ISSUE
driver side window......replaced switch and window motor.....i beleive there is a track that the window sits on......when i roll up the window the track seems to skip and not shut the last 1/2 inch or last inch..........still rolls up and down but sounds like the track is skippin......any idea on what it takes to fix thizz izzue? tha would help.......thanks
Old Jun 28, 2007 | 11:33 AM
g0tgot's Avatar
Bump1
Old Jun 28, 2007 | 11:46 AM
projektCRX's Avatar
Default Re: DRIVER SIDE WINDOW ISSUE (g0tgot)
can you actually see it skipping? w/ the door panel off, just hook up the switch, pull the plastic back and watch the window regulator go up and down and you can see if its "skipping" or atleast see what might be stopping it from going all the way up and down....sounds like work but shouldnt be too bad.. GL
Old Jun 28, 2007 | 11:50 AM
DAmnquickDA's Avatar
Default Re: DRIVER SIDE WINDOW ISSUE (projektCRX)
bump because i have the same exact prob on my DA. only mine is driver side so i get rained on
Old Jun 28, 2007 | 12:46 PM
g0tgot's Avatar
I KNOW i hate that........in fact ......if i have to replace the track.....how hard is that? do i have to take the window out?
Old Jun 28, 2007 | 02:37 PM
projektCRX's Avatar
Default Re: (g0tgot)
i couldn't imagine it to be that difficult, i replaced the regulator on my crx.. and it wasnt bad.. once you have the door panel off, and he plastic off, you have access to everything... worst case scenario, you have to drive to some auto glass shop and have them take care of it.. most of them actually drive to your location.. or atleast in WA ... let me check the haynes manual and see if its detailed enough. and you can pick one of those up..
gqstatus05
Oct 23, 2008 08:51 AM
VSG
Mar 7, 2008 10:46 AM
92ehatch
Mar 3, 2006 02:49 AM
EX-T
Nov 27, 2003 07:26 AM
