possible o2 sensor problem???
K guys hers wat i got its a 99 honda civic hx i did a d16y8 complete swap but had to use the y5 harness... i was runnin the p2p ecu and it ran crappy rough idle... bogged down when u put ur foot in it....no vtec etc. i switched to the p2n ecu and it run much better but still no vtec.... could this be cus i have a 5 wire o2 and the p2p doesnt like that??? any other suggestions????
Re: possible o2 sensor problem???
thats the same problem I ran into with my hx that i did a y8 swap in using the same harness I ended up swapping harness with the y8 harness and it ran great with the p2p ecu then... but to answer your question yes thats the reason being a 5 wire o2 for the y5 harness and the p2p doesn't like that
awesome thanx guys imma rewire that 5 wire to 4 wire tonight and see what i get.... y do i need to run the knock sensor wires??? they are already hooked up
Yuenglinger Hatchbacker
03-06-2006 09:45 AM
exare250
11-24-2004 10:59 AM
Hybridize
10-17-2003 11:37 AM
