Popping out of 2nd gear.
Hello,
I have a civic ex coupe 1999 and it has recently started to pop out of second gear. The motor is the d16y8 it has 250k miles on it and the original transmission *manual obviously*. I've done some research today and i found that it could be bad collars or something with the shift linkage. The problem doesn't happen everytime i shift into second but it happens randomly. I also read that it could be bad mounts causing the transmission to move and popping it out but it also pops out when i try to change gears as smooth as possible. If that even matter. I dont know what my plan of action should be. Tomorrow imma try to check the shift linkage but idk what i should check for. i changed my shift linkage bushings for poly like 5 months ago*poping out started to happen 2 days ago* What should i do ? Thanks in advance
Re: Popping out of 2nd gear.
Well i bought new mounts cuz i needed them anyways and ill be putting them on this weekend. Also, if i hold the shifter when i go into second it stay idk if that means anything or wtv. The weird thing is that ive never had issue with 2nd gear so its so surprising all of the sudden
Fish Twig
Nobody knows what the issue could be until you plan on tearing into the transmission and take some pics of synchros, check for any leaks, etc...etc...
S
S
i cant take the trans out lol i wish i could but i dont have where to do it. Anyways i checked for leaks all around but that wasnt much help cuz i didnt find anything. If the mounts dont work ill go to a reputable shop that works on honda i guess
ADAMnQuickRDX
Transmission & Drivetrain
07-06-2009 10:29 AM
type Gendy
11
05-12-2003 07:01 AM
