Electrical issue after swapping over to power options
OK guys I have an issue with my 1998 Honda Civic Hatchback I wanted all the power options in my hatchback like an EX coupe or an SI so I followed this guide. 96-98 Civic EK Power Window/ Lock/ Mirror Conversion.
Everything in the car works as it should from door locks windows go up and down mirrors can be adjusted. My issue is when I switch over on the mirror switch to the driver side to adjust the mirror angle towards left the door locks trigger and lock.
I want to mention the only part of the how to I did not follow was the wiring for the rear wiper since I deleted that option on my car. I have 2 floor harness both brand new I tried both same issue, I have doubles of the door harness that also did not fix the issue, I have multiple mirror switches also have the same result, I tried different fuse box under the dash also same issue. I tried a different master switch on the driver side that did not help.
I have not changed the dash harness I am kinda at a lost as to what I can do to correct this issue anybody know what might be the issue. If somebody ends up helping me resolve this issue I am willing to paypal for your help really want this issue resolved.
Thanks,
Thanks,
Needs to be About 20% Cooler
1 Post
Re: Electrical issue after swapping over to power options
check all your grounds. my first guess is maybe the or connectors are mis-wired and or you got a short somewhere. the door locks trigger on ground so maybe the mirror motor is trying to ground itself though the door locks.
I have the one by the driver seat contacting bare clean metal and the one under the dash on the other side of the fender touching bare clean metal. Suggestions are welcome.
Same car as this thread?
https://honda-tech.com/honda-civic-d...locks-3222742/
Was this^ issue fixed?
and have multiples on the cabin electrical components this time around.
I have multiple harness for the doors all from the 96-98 range I have multiple switches for the mirror so basically I have doubles and triples of electrical components I been trying to figure out if that was the issue. I hope that helps let me know if you need more info to clarify.
I have two door harness they are from a 96 and a 98 ex coupe I tried both same result.
Yes, both grounds are connected the one you are pointing out here in the diagram and the the one on the floor by the driver seat.
I have sanded down the metal where the loop connectors makes contact with the chassis as well to ensure a good ground.
The problem almost surely reflects the differences between pins 15 and 21 in the floor harness connector C556 and the driver's door harness connector for Civic years 96-97 and Civic year 98.
Fish Twig
Only thing you can do is have the door panel out, get a dsm, and check for continuity to ground when the door locks itself after attempting to adjust your mirror. Once
Time to get technical.
Sounds like there's something going on with the floor harness. That link you provided gives you diagrams for all functions involving the doors. Have you looked into that?
Do you know what the color code should be for a 98? A big thanks for providing the color codes and plug.
Yes I would like to know what the colors of the wires would be for those pin outs for the 98 harness.
I believe I do understand the issue you are indicating that the issue is with those pinouts and the floor harness. So those two need to be checked to make sure they mesh with the floor harness. Am I following you correctly?
Wire colors to and from C556 pins 15 and 21 are shown in both diagrams in post #18.
From what I can tell, your problem can be most easily fixed by swapping the two door harness connector pins corresponding to the two floor harness connector C556 pins 15 and 21.
Understood thanks man if this is the fix I will for sure send you a paypal payment it has been driving me nuts and I have asked so many people to help.
Fish Twig
Thats insane to have a minor change like that happen from a 97 to a 98, was there a reason? I mean it was still obd2a, 96-98 right?
